Mixtures, Solutions and Suspensions
Mixtures
A mixture is a combination of substances which are not chemically joined together.
  • Mixtures have the same properties as their components
  • There is no fixed proportion between the components
  • The components can be separated from the mixture
Examples
  • sugar and salt
  • air with nitrogen and oxygen
Solutions
A solution is a homogeneous mixture in which one substance (solute) is dissolved in another substance (solvent).
  • The components in a solution may not be separated from the solution by leaving it to stand, or by filtration
If a material dissolves in a liquid the material is said to be soluble. A solution is saturated if no more solute can be dissolved with temperature remaining constant.
Examples
  • salt in sea water
Suspensions
A suspension is a mixture of liquids with particles of a solid which may not dissolve in the liquid.
  • The solid may be separated from the liquid by leaving it to stand, or by filtration
Examples
  • sand in water
Basics
The SI-system, unit converters, physical constants, drawing scales and more.
Fluid Mechanics
Concentration Units Converter
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
Ionic Compounds in Water - Solubility Guidelines
Guidelines or solubility rules to predict whether or not a given ionic compound is soluble in water at room temperature.
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Mixing Fluids
Final mass and temperature when mixing fluids.
Naming Inorganic Binary Compounds
Rules for naming inorganic ionic and covalent types of chemical compounds.
Solubility
The amount of a solute that can be dissolved in a solvent.
Solubility Product Constants
The equilibrium constant, Ksp, for aqueous solutions of ionic compounds at 25°C.
Solutions, Molarity and Dilution
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
Sugar Water Solutions - Viscosities
Dynamic viscosities of sucrose water solutions vs. temperature.
