Solubility
Solubility is the ability of a solute to dissolve in a solvent. The solubility of a substance in another is not unlimited, and how much solute you can solve in a solvent varies a lot. Tabulated values of solubility refer to max grams of solute in a given amount of the solvent.
- solubility is dependent on temperature. In general, but not without expectations, solubility increases with temperature
- smaller particles dissolves faster than larger particles
- a solid dissolves faster if the mixture is stirred or shaken
A saturated solution contains the maximum amount of solute in the solvent, given by the solubility.
Examples of common solutions:
- tea with sugar - a solution of sugar in hot water (tea)
- seawater - a solution of salt in water
See more at Solutions, molarity and dilution
See also solubility product constants and solubility guidelines for ionic compounds in water
Example 1
Sodium chloride, NaCl, is the salt used for cooking. This salt has a solubility of 36 g in 100 g of water at 25°C.
What is the concentration (in wt%) of a saturated NaCl water solution at 25°C?
A saturated solution contains the maximum amount of solute in the solvent, which for NaCl is 36 grams in water at 25°C. Then, the concentration of the saturated solution is: g NaCl /g NaCl solution ×100%
NaCl concentration = 36 (g) / (100 + 36) (g) 100% = 26.5 wt%
Example 2
What will be the concentration (in wt%) if you add 34 g NaCl to 100 g of water?
34 g NaCl is less than the solubility, which means that all the salt will be solved in water at 25°C.
NaCl concentration = 34 (g) / (100+34) (g) 100% = 25.4 wt%
Example 3
What will be the concentration (in wt%) of the salt solution if you add 38 g NaCl to 100 g of water?
38 g NaCl is more than the solubility of NaCl in water. This means that the solution will be saturated and some of the salt will remain undissolved at 25°C. The concentration of the saturated solution is the same as in Example 1:
NaCl concentration = 36 (g) / (100 + 36)(g) 100% = 26.5 wt%
• Basics
Boiler Water - Total Dissolved Solids (TDS)
Impurities from the feedwater will concentrate in the boiling water.
Ionic Compounds in Water - Solubility Guidelines
Guidelines or solubility rules to predict whether or not a given ionic compound is soluble in water at room temperature.
Mixtures, Solutions and Suspensions
Mixtures vs. solutions vs. suspensions.
Naming Inorganic Binary Compounds
Rules for naming inorganic ionic and covalent types of chemical compounds.
Percentage
Working with relative values.
Solubility Product Constants
The equilibrium constant, Ksp, for aqueous solutions of ionic compounds at 25°C.
Sugar Solubility in Water
Solubility of sugar in water.
Sugar Water Solutions - Viscosities
Dynamic viscosities of sucrose water solutions vs. temperature.
