Acetone (2-propanone), CH3-CO-CH3, is a clear colorless liquid with a characteristic fruity and sweetish odor. It is flammable and vapors are heavier than air. Acetone is toxic in high doses.
Acetone occurs naturally in plants, trees, forest fires, vehicle exhaust and as a breakdown product of animal fat metabolism. The substance may be normally present in very small quantities in urine and blood; larger amounts may be found in the urine and blood of diabetics. Acetone is used as a solvent in paint and nail polish removers.
The phase diagram of acetone is shown below the table.
Chemical, physical and thermal properties of acetone :
Values are given for liquid at 25 oC (77 oF, 298 K) and 1 bara, if not other phase, temperature or pressure given.
For full table with Imperial units - rotate the screen!
Property | Value | Unit | Value | Unit | Value | Unit | Value | Unit | |||
Acidity (pKa1) | 20 | ||||||||||
Autoignition temperature | 738 | K | 465 | °C | 869 | °F | |||||
Boiling Point | 329.2 | K | 56.08 | °C | 132.9 | °F | |||||
Critical density | 4.70 | mol/dm3 | 273 | kg/m3 | 0.530 | slug/ft3 | 17.0 | lb/ft3 | |||
Critical pressure | 4.69 | MPa=MN/m2 | 46.9 | bar | 46.3 | atm | 681 | psi=lbf/in2 | |||
Critical temperature | 508.1 | K | 235.0 | °C | 454.9 | °F | |||||
Critical volume | 213 | cm3/mol | 0.00366 | m3/kg | 1.89 | ft3/slug | 0.0587 | ft3/lb | |||
Density | 13507 | mol/m3 | 784.5 | kg/m3 | 1.522 | slug/ft3 | 48.97 | lb/ft3 | |||
Flammable, gas and liquid | yes | ||||||||||
Flash point | 256 | K | -17 | °C | 1 | °F | |||||
Gas constant, individual - R | 143.2 | J/kg K | 0.03977 | Wh/(kg K) | 856.1 | (ft lbf/slug °R) | 26.61 | (ft lbf/lb °R) | |||
Gibbs free energy of formation (gas) | -153 | kJ/mol | -2634 | kJ/kg | -1133 | Btu/lb | |||||
Heat (enthalpy) of combustion (gas) | -1821 | kJ/mol | -31354 | kJ/kg | -13.5 | Btu/lb | |||||
Heat (enthalpy) of combustion (liquid) | -1789 | kJ/mol | -30803 | kJ/kg | -13.2 | Btu/lb | |||||
Heat (enthalpy) of formation (gas) | -218.0 | kJ/mol | -3753 | kJ/kg | -1614 | Btu/lb | |||||
Heat (enthalpy) of formation (liquid) | -249 | kJ/mol | -4287 | kJ/kg | -1843 | Btu/lb | |||||
Heat (enthalpy) of fusion at -142 °F/-97°C | 5.7 | kJ/mol | 98 | kJ/kg | 42.19 | Btu/lb | |||||
Heat (enthalpy) of evaporation | 31.0 | kJ/mol | 534 | kJ/kg | 229 | Btu/lb | |||||
Specific Heat capacity, Cp (gas) | 75.0 | J/mol K | 1.29 | kJ/kg K | 0.308 | Btu/lb°F or cal/g K | |||||
Specific Heat capacity, Cp (liquid) | 124.5 | J/mol K | 2.14 | kJ/kg K | 0.512 | Btu/lb°F or cal/g K | |||||
Specific Heat capacity, Cv (liquid) | 90.0 | J/mol K | 1.55 | kJ/kg K | 0.370 | Btu/lb°F or cal/g K | |||||
Ionization potential | 9.69 | eV | |||||||||
log KOW (Octanol/Water Partition Coefficient) | -0.24 | ||||||||||
Melting point | 178.25 | K | -94.9 | °C | -138.8 | °F | |||||
Molecular Weight | 58.079 | g/mol | 0.12804 | lb/mol | |||||||
Solubility in water, at 25°C | 1000 | mg/ml | Miscible with water | ||||||||
Sound velocity | 1164 | m/s | 3818 | ft/s | 2607 | mi/h | |||||
Specific Gravity (gas) (relativ to air) | 2.0 | ||||||||||
Specific Gravity (liquid) (relativ to water) | 0.79 | ||||||||||
Specific Heat Ratio (liquid) - CP/CV | 1.38 | ||||||||||
Specific Volume | 0.0000740 | m3/mol | 0.00127 | m3/kg | 0.657 | ft3/slug | 0.0204 | ft3/lb | |||
Standard molar entropy, S° (gas) | 295 | J/mol K | 5.08 | kJ/kg K | 1.21 | Btu/lb °F | |||||
Surface tension | 23.1 | dynes/cm | 0.02308 | N/m | |||||||
Thermal Conductivity | 0.18 | W/m °C | 0.104002 | Btu/hr ft °F | |||||||
Triple point pressure | 2.33 ×10-6 | MPa=MN/m2 | 2.33 ×10-5 | bar | 2.30 ×10-5 | atm | 3.38 ×10-4 | psi=lbf/in2 | |||
Triple point temperature | 178.5 | K | -94.7 | °C | -138.37 | °F | |||||
Vapor (saturation) pressure | 0.0308 | MPa=MN/m2 | 231.0 | mm Hg | 0.3039 | atm | 4.47 | psi=lbf/in2 | |||
Viscosity, dynamic (absolute) | 0.309 | cP | 207.6 | (lbm/ft s ×10-6) | 6.45 | (lbf s/ft2 ×10-6) | |||||
Viscosity, kinematic | 0.394 | cSt | 4.2 | (ft2/s ×10-6) |
Density and specific weight of acetone at varying pressure and temperature.
as well as Thermophysical properties of: Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene, Water and Heavy water, D2O.
Acetone is a liquid at standard conditions. However, at low temperature and/or very high pressures it becomes a solid.
The phase diagram for acetone shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the acetone boiling point with changes in pressure. It also shows the saturation pressure with changes in temperature.
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Acetylene - Thermophysical Properties
Chemical, Physical and Thermal Properties of Acetylene.
Argon - Thermophysical Properties
Chemical, Physical and Thermal Properties of Argon.
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Monoxide - CO - Thermophysical Properties
Chemical, Physical and Thermal Properties of Carbon Monoxide - CO.
Conductive Heat Transfer
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Heat Capacity
Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Hydrocarbons - Autoignition Temperatures and Flash Points
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Hydrogen sulfide - Thermophysical Properties
Chemical, physical and thermal properties of hydrogen sulfide, H2S, also called hydrosulfuric acid, sewer gas and stink damp. Phase diagram included.
Individual & Universal Gas Constants: Definitions, Values, and Applications
Liquids - Dielectric Constants
Dielectric constants or permittivities of some fluids or liquids.
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Liquids - Vapor Pressures
Vapor and saturation pressure for some common liquids.
Methane (CH₄): Thermophysical Properties and Phase Diagram
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Polyurethane - Chemical Resistance
Chemical resistance of Polyurethane (PUR).
Pressure
Refractive Index common Liquids, Solids and Gases
Some common liquids, solids, and gases and their refractive indexes.
Rubbers and Elastomers - Chemical Resistance
Rsistance to chemicals - solvents and softeners - swelling properties.
Solubility
The amount of a solute that can be dissolved in a solvent.
Speed of Sound - Equations
Calculate the speed of sound (the sonic velocity) in gases, fluids or solids.
Standard State and Enthalpy of Formation, Gibbs Free Energy of Formation, Entropy and Heat Capacity
Definition and explanation of the terms standard state and standard enthalpy of formation, with listing of values for standard enthalpy and Gibbs free energy of formation, as well as standard entropy and molar heat capacity, of 370 inorganic compounds.
Substances Triple Points
Triple points for common substances.
Surface Tension
Surface tension of liquids like water, mercury, oils and more.
