Hydrogen, H2, is a colorless, odorless gas.
Hydrogen is easily ignited. Once ignited it burns with a pale blue, almost invisible flame. The vapors are lighter than air. It is flammable over a wide range of vapor/air concentrations. Hydrogen is not toxic but is a simple asphyxiate by the displacement of oxygen in the air. Under prolonged exposure to fire or intense heat the containers may rupture violently and rocket.
Hydrogen is used to make other chemicals, in petroleum refining and in oxyhydrogen welding and cutting.
The phase diagram of hydrogen is shown below the table.
Chemical, physical and thermal properties of hydrogen:
Values at 25 oC (77 oF, 298 K) and atmospheric pressure
Molecular Weight 2.016
Specific Gravity, air = 1 0.070
Specific Volume (ft3/lb, m3/kg) 194, 12.1
Density of liquid at atmospheric pressure (lb/ft3, kg/m3) 4.43, 71.0
Absolute Viscosity (lbm/ft s, centipoises) 6.05×10-6, 0.009
Sound velocity in gas (m/s) 1315
Specific Heat - cp - (Btu/lb oF or cal/g oC, J/kgK) 3.42, 14310
Specific Heat Ratio - cp/cv 1.405
Gas constant - R - (ft lb/lb oR, J/kg oC) 767, 4126
Thermal Conductivity (Btu/hr ft oF, W/moC) 0.105, 0.182
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - (oF,o K) -423, 20.4
Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) 192, 447000
Freezing or Melting Point  at 1 atm (oF, oC) -434.6, -259.1
Latent Heat of Fusion (Btu/lb, J/kg) 25.0, 58000
Critical Temperature (oF, oC) -399.8, -240.0
Critical Pressure (psia, MN/m2) 189, 1.30
Critical Volume (ft3/lb, m3/kg) 0.53, 0.033
Flammable yes
Heat of combustion (Btu/ft3, Btu/lb, kJ/kg) 320, 62050, 144000
Follow the links below to get values for the listed properties of hydrogen at varying pressure and temperature :
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen sulfide, Methane, Methanol, Nitrogen, Oxygen, Pentane, Propane, Toluene, Water and Heavy water, D2O.
Hydrogen is a gas at standard conditions. However, at very low temperature and/or high pressures the gas becomes a liquid or a solid.
The hydrogen phase diagram shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the hydrogen boiling point with changes in pressure. It also shows the saturation pressure with changes in temperature.
Material Properties
Combustion Heat
Cryogenic Fluids and Liquefied Gas Properties
Cryogenic properties as density, boiling points and heat of evaporation for fluids like hydrogen, methane, oxygen, nitrogen, fluorine and helium.
Density of Gases
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Helium - Thermophysical Properties
Chemical, Physical and Thermal Properties of Helium - He.
Hydrogen - Specific Heat
Specific heat of Hydrogen Gas - H2 - at temperatures ranging 175 - 6000 K.
