Chemical, physical and thermal properties of Oxygen - O2 :
(Values at 25 oC (77 oF, 298 K) and atmospheric pressure)
| Molecular Weight | 31.9988 |
| Specific Gravity, air = 1 | 1.105 |
| Specific Volume (ft3/lb, m3/kg) | 12.24, 0.764 |
| Density of liquid at atmospheric pressure (lb/ft3, kg/m3) | 71.27, 1142 |
| Absolute Viscosity (lbm/ft s, centipoises) | 13.4×10-6, 0.020 |
| Sound velocity in gas (m/s) | 329 |
| Specific Heat - cp - (Btu/lb oF or cal/g oC, J/kgK) | 0.220, 920 |
| Specific Heat Ratio - cp/cv | 1.40 |
| Gas constant - R - (ft lb/lb oR, J/kg oC) | 48.3, 260 |
| Thermal Conductivity (Btu/hr ft oF, W/moC) | 0.015, 0.026 |
| Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - (oF, oC) | -297.3, -182.97 |
| Latent Heat of Evaporation at boiling point (Btu/lb, J/kg) | 91.7, 213000 |
| Freezing or Melting Point at 1 atm (oF, oC) | -361.1, -218.4 |
| Latent Heat of Fusion (Btu/lb, J/kg) | 5.9, 13700 |
| Critical Temperature (oF, oC) | -181.5, -118.6 |
| Critical Pressure (psia, MN/m2) | 726, 5.01 |
| Critical Volume (ft3/lb, m3/kg) | 0.040, 0.0025 |
| Flammable | no |
Follow the links below to get values for the listed properties of oxygen at varying pressure and temperature :
as well as Thermophysical properties of: Acetone, Acetylene, Air, Ammonia, Argon, Benzene, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Helium, Hydrogen, Hydrogen sulfide, Methane, Methanol, Nitrogen, Pentane, Propane, Toluene, Water and Heavy water, D2O.
Oxygen is a gas at standard conditions. However, at low temperature and/or high pressures the gas becomes a liquid or a solid.
The oxygen phase diagram shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the oxygen boiling point with changes in pressure. It also shows the saturation pressure with changes in temperature.
Combustion Efficiency and Excess Air
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Cryogenic Fluids and Liquefied Gas Properties
Cryogenic properties as density, boiling points and heat of evaporation for fluids like hydrogen, methane, oxygen, nitrogen, fluorine and helium.
Density of Gases
Oxygen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of oxygen as an ideal gas.
Solubility of oxygen in equilibration with air in fresh water and seawater (salt water) - pressures ranging 1 - 4 bar abs.
Specific heat of Oxygen Gas - O2 - at temperatures ranging 175 - 6000 K.
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Steel Pipes - Corrosion due to Oxygen
The influence of oxygen concentration and temperature on the corrosion of steel pipes.
Stoichiometric Combustion
Stoichiometric combustion and excess air.
