(values at 25 o C (77 o F, 298 K) and atmospheric pressure)
Molecular Weight | 58.12 |
Specific Gravity , air = 1 | 2.07 |
Specific Volume ( ft 3 /lb, m 3 /kg ) | 6.5, 0.405 |
Density of liquid at atmospheric pressure ( lb/ft 3 , kg/m 3 ) | 37.5, 604 |
Vapor pressure at 25 o C ( psia, MN/m 2 ) | 35.4, 0.244 |
Absolute Viscosity ( lb m /ft s, centipoises ) | 4.8 10 -6 , 0.007 |
Sound velocity in gas ( m/s ) | 216 |
Specific Heat - c p - ( Btu/lb o F or cal/g o C, J/kgK ) | 0.39, 1675 |
Specific Heat Ratio - c p /c v | 1.096 |
Gas constant - R - ( ft lb/lb o R, J/kg o C ) | 26.56, 143 |
Thermal Conductivity ( Btu/hr ft o F, W/m o C ) | 0.01, 0.017 |
Boiling Point - saturation pressure 14.7 psia and 760 mm Hg - ( o F, o C ) | 31.2, -0.4 |
Latent Heat of Evaporation at boiling point ( Btu/lb, J/kg ) | 165.6, 386000 |
Freezing or Melting Point at 1 atm ( o F, o C ) | -217, -138 |
Latent Heat of Fusion ( Btu/lb, J/kg ) | 19.2, 44700 |
Critical Temperature ( o F, o C ) | 306, 152 |
Critical Pressure ( psia, MN/m 2 ) | 550, 3.8 |
Critical Volume ( ft 3 /lb, m 3 /kg ) | 0.070, 0.0043 |
Flammable | yes |
Heat of combustion ( Btu/ft 3 , Btu/lb, kJ/kg ) | 3300, 21400, 49700 |
Follow the links below to get values for the listed properties of butane at varying pressure and temperature :
as well as Thermophysical properties of: Acetone , Acetylene , Air , Ammonia , Argon , Benzene , Carbon dioxide , Carbon monoxide , Ethane , Ethanol , Ethylene , Helium , Hydrogen , Hydrogen sulfide , Methane , Methanol , Nitrogen , Oxygen , Pentane , Propane , Toluene , Water and Heavy water, D 2 O .
Butane is a gas at standard conditions. However, at lower temperature and/or high pressures the gas becomes a liquid or a solid.
The butane phase diagram shows the phase behavior with changes in temperature and pressure. The curve between the critical point and the triple point shows the butane boiling point with changes in pressure. It also shows the saturation pressure with changes in temperature.
The flash points for some common liquids and fuels.
Adiabatic flame temperatures for common fuel gases - propane, butane, acetylene and more - in air or oxygen atmospheres.
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Gross heat and net heat values for gases like hydrogen, methane and more.
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
Liquefied Petroleum - LP - gas properties.
Triple points for common substances.
