Heating Values of Fuel Gases
Fuel gases gross and net heating values:
| Gas | Gross Heating Value | Net Heating Value | ||
| (Btu/ft3) | (Btu/lb) | (Btu/ft3) | (Btu/lb) | |
| Acetylene (ethyne) - C2H2 | 1498 | 21569 | 1447 | 20837 |
| Ammonia (Liquefied, cooled compressed) | 8017 | |||
| Benzene | 3741 | 18150 | 3590 | 17418 |
| Blast Furnace gas | 92 | 1178 | 92 | 1178 |
| Blue water gas | 6550 | |||
| Butane - C4H10 | 3225 | 21640 | 2977 | 19976 |
| Butylene (Butene) | 3077 | 20780 | 2876 | 19420 |
| Carbon to CO2 | 14150 | 14150 | ||
| Carbon to CO | 3960 | 3960 | ||
| Carbon monoxide - CO | 323 | 4368 | 323 | 4368 |
| Carburetted Water Gas | 550 | 11440 | 508 | 10566 |
| Coal gas | 149 | 16500 | ||
| Coke Oven Gas | 574 | 17048 | 514 | 15266 |
| Digester Gas (Sewage or Biogas) | 690 | 11316 | 621 | 10184 |
| Ethane - C2H6 | 1783 | 22198 | 1630 | 20295 |
| Ethyl alcohol saturated with water | 1548 | 12804 | ||
| Ethylene | 1631 | 21884 | 1530 | 20525 |
| Hexane | 4667 | 20526 | 4315 | 18976 |
| Hydrogen (H2) | 325 | 61084 | 275 | 51628 |
| Hydrogen Sulphide | 672 | 7479 | ||
| Landfill Gas | 476 | |||
| Methane - CH4 | 1011 | 23811 | 910 | 21433 |
| Methyl alcohol saturated with water | 818 | 9603 | ||
| Naphthalene | 5859 | 17298 | ||
| Natural Gas (typical) | 950 - 1150 |
19500 - 22500 |
850 - 1050 |
17500 - 22000 |
| Octane saturated with water | 6239 | 20542 | 3170 | 10444 |
| Pentane | 3981 | 20908 | 3679 | 19322 |
| Producer gas | 2470 | |||
| Propane - C3H8 | 2572 | 21564 | 2371 | 19834 |
| Propene (Propylene) - C3H6 | 2332 | 20990 | 2181 | 19630 |
| Propylene | 2336 | 21042 | 2185 | 19683 |
| Sasol | 500 | 14550 | 443 | 13016 |
| Sulphur | 3940 | |||
| Toluene | 4408 | 18291 | 4206 | 17301 |
| Water Gas (bituminous) | 261 | 4881 | 239 | 4469 |
| Xylene | 5155 | 18410 | ||
- 1 Btu/ft3 = 8.9 kcal/m3 = 3.73×104 J/m3
- 1 Btu/lb = 2,326.1 J/kg = 0.55556 kcal/kg
• Combustion
Acetylene - Thermophysical Properties
Chemical, Physical and Thermal Properties of Acetylene.
Biogas - Carbon Nitrogen Ratios
Carbon - Nitrogen ratios for biogas produced from various raw materials.
Biogas - Composition
Typical composition of biogas produced from household waste.
Biogas - Energy Content
Energy content in biogas produced from municipal and industrial waste.
Biogas - Potential from Animal Manure
Potential biogas production from animal manure.
Biomasses - Higher Heating Values
Some biomass fuels and their higher heating values (HHV).
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Combustion Heat
Combustion Processes and Combustion Efficiency
Typical furnace combustion efficiencies in fireplaces, space heaters, boilers and more.
Energy Content in common Energy Sources
Heating fuels and their energy content.
Ethane Gas - Specific Heat vs. Temperature
Specific heat of Ethane Gas - C2H6 - for temperatures ranging 250 - 900 K.
Ethane Liquid - Thermal Properties
Density, specific heat and more of liquid ethane.
Food - Calorific Combustion Values
Combustion heat values of some foods.
Gas Oil - Classification
Classification of gas oil based on BS 2869 - Specification for fuel oils for agricultural, domestic and industrial engines and boilers.
Gases - Gross and Net Heat Values
Gross heat and net heat values for gases like hydrogen, methane and more.
Gasoline - Density, Specific Heat, Viscosity and Thermal Conductivity vs. Temperature
High and Low Heat Values
The gross (high) and net (low) heating values.
Hydrocarbons - Vapor Pressures
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
Methane (CHâ‚„): Thermophysical Properties and Phase Diagram
Octane Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
Waste Fuel - Heat Values
Fuel from waste products and their heat values.
