Waste Fuel - Heat Values
ProductHeat Value
(Btu/lb)
Fabric - nylon 13200
Fabric - rubber coated 11000
Fabric - vinyl coated 8900
Foam - scrap 12300
Garbage 8480
Glass tape - resin covered 7900
Paper 7570
Polyethylene - film 19100
Rags 7650
Vinyl - scrap 11400
Wood 8610
  • 1 Btu/lb = 2.326 kJ/kg = 0.55 kcal/kg
Combustion
Biomasses - Energy Content when Used as Fuel
Biomass fuels and their energy content.
Combustion Heat
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Energy Content in common Energy Sources
Heating fuels and their energy content.
Food - Calorific Combustion Values
Combustion heat values of some foods.
Fossil vs. Alternative Fuels - Energy Content
Net (low) and gross (high) energy content in fossil and alternative fuels.
Fuel Gases - Heating Values
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Fuel Oil Combustion Values
Combustion values in Btu/gal for fuel oils No.1 to No.6.
Fuels - Higher and Lower Calorific Values
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
High and Low Heat Values
The gross (high) and net (low) heating values.
Wood and Bio Mass - Combustion Heat
Combustion heat values for wet and dry wood - Btu/pounds, kJ/kg and kcal/kg.
