Climate, meteorology, sun, wind and environmental related engineering resources.
Properties of alternative fuels like biodiesel, E85, CNG and more.
Biomass fuels and their energy content.
Calculator for CO2 emissions from trains, comparing with alternative forms of transportation (as plane, bus, conventional and electrical cars).
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
Classification of coal based on volatile matter and cooking power of clean material.
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Combustion heat values of some foods.
Net (low) and gross (high) energy content in fossil and alternative fuels.
Convert between fuel consumption units like US MPG, Imperial MPG, litre/nm, litre/100 km and km/litre
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Heat vs. work vs. energy.
Cost comparison formulas for heating fuels like Natural Gas, Propane LP Gas, Fuel Oil and Electricity.
Emission of Nitrogen Oxides - NOx - with combustion of fuels like oil, coal, propane and more.
Stable and efficient combustion requires correct mixture of fuels and oxygen.
Standard grades coal heat values.
Fuel from waste products and their heat values.
Yields of different crude oil distillation cuts are plotted as function of whole crude specific gravity. Fractions based on European and North American markets, and the typical differences in crude oil fractionation in the two markets are also shown.
