Food - Calorific Combustion Values
The calorific value of a fuel or food is the amount of heat produced with complete combustion.
FoodCalorific Combustion Value
(MJ/kg)
Butter 30.5
Cheese 14.6
Curd 2.5
Egg, yolk 5.4
Egg, white 14.0
Fish 5.2
Ghee 37.6
Meat 12.0
Milk, buffalo 4.9
Milk, cow 2.2
Potatoes 4.0
Rice 16.7
Soyabean 18.1
Sugar 16.0
Normal energy consumption for a young male is about 10 MJ/day.
Combustion
Combustion Heat
Fossil vs. Alternative Fuels - Energy Content
Net (low) and gross (high) energy content in fossil and alternative fuels.
Fuel Gases - Heating Values
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Fuel Oil Combustion Values
Combustion values in Btu/gal for fuel oils No.1 to No.6.
Fuels - Higher and Lower Calorific Values
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Gases - Gross and Net Heat Values
Gross heat and net heat values for gases like hydrogen, methane and more.
Gross Combustion Values for some common Materials
Gross combustion values for materials like - carbon, methane, ethylene and more - values in Btu/lb.
High and Low Heat Values
The gross (high) and net (low) heating values.
Paraffins and Alkanes - Combustion Properties
Properties like heat values, air/fuel ratios, flame speed, flame temperatures, ignition temperatures, flash points and flammability limits.
Standard Grade Coal - Heat Values
Standard grades coal heat values.
Waste Fuel - Heat Values
Fuel from waste products and their heat values.
Wood - Combustion Heat Values
Combustion of wood and firewood heat values for species like Pine, Elm, Hickory and more.
