Wood - Combustion Heat Values
Type of wood - whether it is hardwood or softwood - burned in the combustion process is important for the heat value and the energy efficiency.
Hardwoods have less resin and burn slower and longer. Softwoods burn quickly. In addition the seasoned length influences on the fuel efficiency. Seasoning the wood refers to the allowed drying time before combustion.
Wood need to be dried at least 4 to 6 months before use.
Densities and heat values of some common wood species are indicated in the table below. Note that the volume of a stack of firewood varies considerably on whether or not it is split and how it is stacked. The moisture content also play a role - the values below are based on a average moisture content of 20%.
Wood Species | Density of Dry Wood (lb/ft3) | Weight of Dry Cord (lb/cord) | Recoverable Heat Value of Cord (Dry Wood) (millions Btu/cord) | Heat Value of Cord (Green Wood) (millions Btu/cord) | Units of Green Wood needed to produce 1 Million (cord/Btu's) |
Apple | 48.7 | 4100 | 26.5 | 18.6 | 0.054 |
Ash, white | 22.3 | ||||
Aspen | 27 | 2290 | 14.7 | 10.3 | 0.097 |
Balsam Fir | 26.3 | 2240 | 14.3 | 10.0 | 0.10 |
Basswood | 24.8 | 2110 | 13.5 | 9.5 | 0.106 |
Beech | 44.2 | 3760 | 24 | 16.8 | 0.060 |
Birch | 21.7 | ||||
Black Ash | 35.2 | 2990 | 19.1 | 13.4 | 0.075 |
Black Spruce | 29.2 | 2480 | 15.9 | 11.1 | 0.090 |
Box elder | 32.9 | 2800 | 17.9 | 12.5 | 0.080 |
Buckeye | 13.4 | ||||
Butternut | 15.4 | ||||
Catalpa | 16.4 | ||||
Cherry | 36.7 | 3120 | 20 | 14 | 0.071 |
Chestnut | 12.9 | ||||
Coffee tree | 21.6 | ||||
Cottonwood | 24.8 | 2110 | 13.5 | 9.5 | 0.106 |
Dogwood | 27.0 | ||||
Douglas Fir | 26.4 | ||||
East Hop hornbeam | 50.2 | 4270 | 27.3 | 19.1 | 0.052 |
Elm | 35.9 | 3050 | 19.5 | 13.7 | 0.073 |
Hackberry | 38.2 | 3250 | 20.8 | 14.6 | 0.069 |
Hemlock | 29.2 | 2480 | 15.9 | 11.1 | 0.090 |
Hickory | 50.9 | 4330 | 27.7 | 19.4 | 0.052 |
Ironwood | 26.0 | ||||
Jack Pine | 31.4 | 2670 | 17.1 | 12.0 | 0.084 |
Larch - Eastern | 18.7 | ||||
Locust | 27.3 | ||||
Lodgepole pine | 19.3 | ||||
Maple | 21.6 | ||||
Mulberry | 25.8 | ||||
Norway Pine | 31.4 | 2670 | 17.1 | 12.0 | 0.084 |
Osage Orange | 32.9 | ||||
Paper Birch | 37.4 | 3180 | 20.3 | 14.2 | 0.070 |
Pinon Pine | 33.5 | ||||
Ponderosa Pine | 28 | 2380 | 15.2 | 10.6 | 0.094 |
Redcedar - east | 19.8 | ||||
Red Oak | 44.2 | 3760 | 24 | 16.8 | 0.060 |
Red Maple | 34.4 | 2920 | 18.7 | 13.1 | 0.076 |
Spruce | 16.0 | ||||
Sucamore | 19.5 | ||||
Sugar Maple | 44.2 | 3760 | 24 | 16.8 | 0.060 |
Tamarack | 38.2 | 3250 | 20.8 | 14.6 | 0.069 |
Tanarack pine | 21.2 | ||||
Yellow Birch | 43.4 | 3690 | 23.6 | 16.5 | 0.061 |
Yellow pine | 22.0 | ||||
Walnut - black | 21.5 | ||||
White Ash | 43.4 | 3690 | 23.6 | 16.5 | 0.061 |
White Oak | 47.2 | 4010 | 25.7 | 18.0 | 0.056 |
White Pine | 26.3 | 2240 | 14.3 | 10.0 | 0.100 |
Willow | 13.2 |
- 1 ft (foot) = 0.3048 m
- 1 lb = 0.4536 kg
- 1 lb/ft3 = 16.018 kg/m3
- 1 Btu (British thermal unit) = 1,055.06 J = 107.6 kpm = 2.931×10-4 kWh = 0.252 kcal = 778.16 ft lbf = 1.055×1010 ergs = 252 cal = 0.293 watt hour
Note that in the table above 1 net cord volume = 85 ft3 is used to convert between the "Density" and "Weight of Cord" column (1 stacked cord volume = 128 ft3). Be aware that the densities used for the wood species varies significantly. The densities used above is for natural dried wood where the average moisture content is approximately 20%.
Heat values of cords with dry wood can be estimated by adding 10% to the green wood cords values.
Recoverable heat values are calculated with a stove efficiency of approximately 65%.
How to Calculate the Combustion Heat in MJ/kg from the Table above
- calculate "Density of Dry Wood" in kg/m3 by multiplying lb/ft3 with 16.018
- calculate "Weight of Dry Wood" in kg/cord by multiplying lb/cord with 0.4536
- calculate "Recoverable Heat Value of Cord (Dry Wood)" in MJ/cord by multiplying Millions Btu/cord with 1055.06
- calculate "Recoverable Heat Value per kg (Dry Wood)" in MJ/kg by dividing 3 with 2
Example - Red Oak
- "Density of Dry Wood" : 44.2 (lb/ft3) 16.018 = 708 (kg/m3)
- "Weight of Dry Wood" : 3760 (lb/cord) 0.4536 = 1705.5 (kg/cord)
- "Recoverable Heat Value of Cord (Dry Wood)" : 24.0 (Millions Btu/cord) 1055.06 = 25304 (MJ/cord)
- "Recoverable Heat Value per kg (Dry Wood)" : 25304 (MJ/cord) / 1705.5 (kg/cord) = 14.8 (MJ/kg)
The Combustion Process of Burning Wood
- Wood heats up to approximately 212 oF (100 oC) evaporating the moisture in it. There is no heating from the wood at this point
- Wood solids starts to break down converting the fuel gases (near 575 oF, 300 oC)
- From 575 oF to 1100 oF (300 - 600 oC) the main energy in the wood is released when fuel vapors containing 40% to 60% of the energy burn
- After the burning of fuel vapors and the moisture is evaporated, only charcoal remains burning at temperatures higher than 1100o F
- TC = 5 / 9 (TF - 32)
• Combustion
• Heating Systems
Density of Wood Species: Data & Material Guide
Fire Wood - the Cord
The cord unit for purchasing fuel wood.
Food - Calorific Combustion Values
Combustion heat values of some foods.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
High and Low Heat Values
The gross (high) and net (low) heating values.
Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Paraffins and Alkanes - Combustion Properties
Properties like heat values, air/fuel ratios, flame speed, flame temperatures, ignition temperatures, flash points and flammability limits.
Tree Species - Water Demand
Trees species and relative water demand.
Urban Tree Heights
Height of trees commonly used in towns and urban areas.
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood and Bio Mass - Combustion Heat
Combustion heat values for wet and dry wood - Btu/pounds, kJ/kg and kcal/kg.
