Wood - Density vs. Moisture Content
Density of wood versus content of water can be calculated as
ρ = 62.4 (SG / (1 + 0.009 SG m)) (1 + m / 100) (1)
ρ = density of wood (lb/ft3)
m = moisture content in wood (%)
- 1 lb/ft3 = 16.018 kg/m3 = 0.016 g/cm3 = 0.00926 oz/in3 = 2.57 oz/gal (Imperial) = 2.139 oz/gal (U.S.) = 0.0005787 lb/in3 = 27 lb/yd3 = 0.161 lb/gal (Imperial) = 0.134 lb/gal (U.S) = 0.0121 ton/yd3
• Densities
Density of Wood Species: Data & Material Guide
Fire Wood - the Cord
The cord unit for purchasing fuel wood.
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Tree Species - Water Demand
Trees species and relative water demand.
Urban Tree Heights
Height of trees commonly used in towns and urban areas.
Wood - Combustion Heat Values
Combustion of wood and firewood heat values for species like Pine, Elm, Hickory and more.
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
The density of wood versus moisture content.
Wood and Bio Mass - Combustion Heat
Combustion heat values for wet and dry wood - Btu/pounds, kJ/kg and kcal/kg.
Wood Beams - Strength of Material
Wood Columns - Safe Loads
Safe loads for wood columns.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
