Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
The density and weight of lumber varies with the water or moisture content in the wood. Typical weights for green, kiln dried and pressure treated lumber boards are indicated in the tables below.
Note that nominal dimensions are not the same as actual lumber dimensions.
Green Lumber Boards
Green Lumber Boards - Weights
Weight (lb)
Nominal
Dimension
(in x in)
Length (ft)
18101216
2 x 4 1.7 13 17 20 27
4 x 4 3.6 29 36 43 58
4 x 6 5.4 43 54 65 86
4 x 8 7.2 58 72 86 115
4×10 9 72 90 108 144
4 x 12 10.8 86 108 130 173
6 x 6 8.1 65 81 97 130
Drying lumber takes time. Smaller and shorter boards use considerable less time than larger and longer boards. For larger pieces natural drying takes months and often even more than a year - depending on the surrounding temperature, moisture and air circulation. Smaller shorter pieces can dry in weeks.
Kiln Dried Lumber Boards
Kiln Dried Lumber Boards - Weights
Weight (lb)
Nominal
Dimension
(in x in)
Length (ft)
18101216
2 x 4 1.3 11 13 16 21
2 x 6 2 16 20 24 32
2 x 8 2.7 21 27 32 43
2×10 3.3 27 33 40 53
2 x 12 4 32 40 48 64
  • Right click the chart and open in new window for printing
Example - Estimating Shipment Weight of Lumber
The shipment weight of 600 ft of 2 x 4 dried lumber can be estimated from the chart to be approximately
800 lb
Pressure Treated Lumber Boards
Pressure treated with chemical preservatives.
Pressure Treated Lumber Boards - Weights
Weight (lb)
Nominal
Dimension
(in x in)
Length (ft)
18101216
2 x 4 2.1 17 21 26 34
2 x 6 3.2 26 32 38 51
2 x 8 4.4 35 44 53 70
2×10 5.5 44 55 66 88
2 x 12 6.6 53 66 79 106
4 x 4 4.8 38 48 58 77
4 x 6 7 56 70 84 112
4 x 8 9.3 75 93 112 149
4 x10 11.7 93 117 140 187
4 x 12 14 112 140 168 224
Material Properties
Board Feet Chart and Calculator
Board feet is used as a volume measurement of lumber.
Density of Wood Species: Data & Material Guide
Fire Wood - the Cord
The cord unit for purchasing fuel wood.
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Softwood Lumber - Dimensions
Commercial softwood lumber dimension chart - nominal and actual sizes.
Softwood Lumber - Grading
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Softwood Lumber - Standard Sizes
Nominal and minimum-dressed lumber sizes.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Structural Lumber - Properties
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Wood - Combustion Heat Values
Combustion of wood and firewood heat values for species like Pine, Elm, Hickory and more.
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood and Bio Mass - Combustion Heat
Combustion heat values for wet and dry wood - Btu/pounds, kJ/kg and kcal/kg.
Wood Beams - Strength of Material
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Headers - Max. Supported Weight
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
