Structural Lumber - Properties
Structural Lumber - Dimensions and Static Properties
Nominal Dimension
(in)
Actual Dimension
(in)
Area
(in2)
Section Modulus
- S -
(in3)
Moment of Inertia
- I -
(in4)
Weight
(lb/ft)
1 x 3 0.75 x 2.5 1.875 0.47
1x 4 0.75 x 3.5 2.625 0.64
1 x 6 0.75 x 5.5 4.125 1.0
1 x 8 0.75 x 7.25 5.4375 1.3
1 x 10 0.75 x 9.25 6.9375 1.7
1 x 12 0.75 x 11.25 8.4375 2.1
2 x 3 1.5 x 2.5 3.75 1.56 1.95 0.9
2 x 4 1.5 x 3.5 5.25 3.06 5.36 1.3
2 x 6 1.5 x 5.5 8.25 7.56 20.8 2.0
2 x 8 1.5 x 7.25 10.875 13.1 47.6 2.6
2 x 10 1.5 x 9.25 13.875 21.4 98.9 3.4
2 x 12 1.5 x 11.25 16.875 31.6 178 4.1
3 x 2 2.5 x 1.5 3.75 0.94 0.70 0.9
3 x 4 2.5 x 3.5 8.75 5.10 8.93 2.1
3 x 6 2.5 x 5.5 13.75 12.6 34.7 3.3
3 x 8 2.5 x 7.25 18.125 21.9 79.4 4.4
3 x 10 2.5 x 9.25 23.125 35.7 165 5.6
3 x 12 2.5 x 11.25 28.125 52.7 297 6.8
4 x 2 3.5 x 1.5 5.25 1.31 0.98 1.3
4 x 3 3.5 x 2.5 8.75 3.64 4.56 2.1
4 x 4 3.5 x 3.5 12.25 7.15 12.5 3.0
4 x 6 3.5 x 5.5 19.25 17.6 48.5 4.7
4 x 8 3.5 x 7.25 25.375 30.7 111 6.2
4 x 10 3.5 x 9.25 32.375 49.9 231 7.9
4 x 12 3.5 x 11.25 39.375 73.8 415 9.6
6 x 2 5.5 x 1.5 8.25 2.1 1.55 2.0
6 x 3 5.5 x 2.5 13.8 5.7 7.16 3.3
6 x 4 5.5 x 3.5 19.3 11.2 19.7 4.7
6 x 6 5.5 x 5.5 30.3 27.7 76.3 7.4
6 x 8 5.5 x 7.5 41.3 51.6 193 10.0
6 x 10 5.5 x 9.5 52.3 82.7 393 12.7
6 x 12 5.5 x 11.5 63.3 121 697 15.4
8 x 2 7.25 x 1.5 10.9 2.7 2.04 2.6
8 x 3 7.25 x 2.5 18.1 7.6 9.44 4.4
8 x 4 7.25 x 3.5 25.4 14.8 25.9 6.2
8 x 6 7.5 x 5.5 41.3 37.8 104 10.0
8 x 8 7.5 x 7.5 56.3 70.3 264 13.7
8 x 10 7.5 x 9.5 71.3 113 536 17.3
8 x 12 7.5 x 11.5 86.3 165 951 21.0
8 x 14 7.5 x 13.5 101 228 1538 24.6
8 x 16 7.5 x 15.5 116 300 2327 28.3
10 x 10 9.5 x 9.5 90.3 143 679 21.9
10 x 12 9.5 x 11.5 109 209 1204 26.6
10 x 14 9.5 x 13.5 128 289 1948 31.2
10 x 16 9.5 x 15.5 147 380 2948 35.8
10 x 18 9.5 x 17.5 166 485 4243 40.4
12 x 12 11.5 x 11.5 132 32.1
12 x 14 11.5 x 13.5 152 37.7
12 x 16 11.5 x 15.5 178 43.3
  • 1 in = 25.4 mm
  • 1 in2 = 6.45x102 mm2
  • 1 in3 = 1.64x104 mm3
  • 1 in4 = 4.16x105 mm4
  • 1 lb/ft = 1.49 kg/m
Based on standard commercially available lumber within the USA.
Use the Engineering ToolBox - SketchUp Extension - to add Construction Lumber to Your Models
Beams and Columns
Area Moment of Inertia - Typical Cross Sections I
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Hardwood and Softwood Species
Species of hardwood vs. softwood.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Lumber - Weights
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Miter Saw - Calculate Sawing Angle
Calculate miter saw protractor angles for skirting and decorative mouldings work.
Nails and Spikes - Withdrawal Force
Allowable withdrawal load for nail and spikes.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Softwood Lumber - Dimensions
Commercial softwood lumber dimension chart - nominal and actual sizes.
Softwood Lumber - Grading
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Softwood Lumber - Standard Sizes
Nominal and minimum-dressed lumber sizes.
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Three-Hinged Arches - Continuous and Point Loads
Support reactions and bending moments.
Tree Species - Water Demand
Trees species and relative water demand.
Trusses
Common types of trusses.
Urban Tree Heights
Height of trees commonly used in towns and urban areas.
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
Wood Beams - Strength of Material
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Species - Densities
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
