Miter Saw - Calculate Sawing Angle
The miter saw angles for cross cuts and decorative mouldings in corners or other locations can often be hard to measure correctly.
With this tool you measure the three lengths a, b and c as indicated in the drawing below. The miter saw cutting angles are easily calculated by inputting the values in the miter saw calculator below.
length a (mm, in)
length b (mm, in)
length c (mm, in)
- Angle A (deg):
- Angle B (deg):
- Angle C (deg):
- Miter Saw Angle (deg):
- Skirting (Decorative Moulding) Saw Angle (deg):
The Skirting Saw Angle can be useful when cutting decorative mouldings, skirting boards and similar where the angle between the pieces are not 90 degrees and the cross cuts are not 45 degrees.
Tip! - Distance c can be difficult to measure in corners. It may be helpful to use a stick or something similar with a known length for c. Position the stick somewhere in the corner as indicated in the drawings below. Measure the lengths a and b from the bottom of the corner to the ends of the stick.
Examples - Miter Saw Angle Calculator
The first example below with the default values used in the calculator above calculates the miter saw angle to 26.4 degrees for length a = 33.5, b = 40 and c = 39.1.
The second example calculates the miter saw angle to -26.5 degrees (miter saw opposite side compared to the first example) for lengths a = 33.5, b = 4 and c = 62.6.
Angle Converter
Converting between angle units.
Board Feet Chart and Calculator
Board feet is used as a volume measurement of lumber.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Law of Tangents
Triangles and law of tangents.
Lumber - Surface Finishing
Lumber and surface finishing abbreviations.
Lumber - Weights
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Oblique Triangle
Calculate oblique triangles.
Pythagorean Theorem
Verifying square corners.
Right Angled Triangle
Right angled triangle equations.
Slope - Degree, Gradient and Grade Calculator
Convert slopes pitch between degrees, gradients and grades.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Softwood Lumber - Dimensions
Commercial softwood lumber dimension chart - nominal and actual sizes.
Softwood Lumber - Grading
Rough lumber, surfaced lumber (dressed), worked lumber, shop and factory lumber and yard lumber.
Softwood Lumber - Standard Sizes
Nominal and minimum-dressed lumber sizes.
Steel Angles - Equal Legs
Steel Angles - Unequal Legs
Structural Lumber - Section Sizes
Basic size, area, moments of inertia and section modulus for timber - metric units.
Structural Lumber - Properties
Triangle
Triangle analytical geometry.
Trigonometric Functions
Sine, cosine and tangent - the natural trigonometric functions.
Wood Columns - Safe Loads
Safe loads for wood columns.
Wood Species - Densities
