Trigonometric Functions
Natural trigonometric functions are expressed as
sin(θd) = a / c
= 1 / csc(θd)
= cos(π/2 - θr)                              (1)
θd = angle in degrees
θr = angle in radians
cos(θd) = b / c
= 1 / sec(θd)
= sin(π/2 - θr)                               (2)
tan(θd) = a / b
= 1 / cot(θd)
= sin(θd) / cos(θd)
= cot(π/2 - θr )                                     (3)
cot(θd) = 1 / tan(θd)
= cos(θd) / sin(θd)
= tan(π/2 - θr)                          (4)
Trigonometric functions ranging 0 to 90 degrees are tabulated below:
Inverse functions
arcsin(a) = sin-1(a)                                   (1a)
arccos(a) = cos-1(a)                                   (2a)
arctan(a) = tan-1(a)                                     (3a)
Addition Formula
sin(a ± b) = sin(a) cos(b) ± cos(a) sin(b)                             (5)
cos(a ± b) = cos(a) cos(b) ± sin(a) sin(b)                            (5b)
tan(a ± b) = (tan(a) ± tan(b)) / (1 ± tan(a) tan(b))                         (5c)
Sum and Difference Formula
sin(a) + sin(b) = 2 sin((a + b)/2) cos((a + b)/2)                          (6)
sin(a) - sin(b) = 2 cos((a + b)/2) sin((a - b)/2)                          (6b)
cos(a) + cos(b) = 2 cos((a + b)/2) cos((a - b)/2)                          (6c)
cos(a) - cos(b) = - 2 sin((a + b)/2) sin((a - b)/2)                         (6d)
tan(a) + tan(b) = sin(a + b) / (cos(a) cos(b))                       (6e)
tan(a) - tan(b) = sin(a - b) / (cos(a) cos(b))                    (6f)
Product Formula
2 sin(a) cos(b) = sin(a - b) + sin(a + b)                       (7)
2 sin(a) sin(b) = cos(a - b) - cos(a - b)                      (7b)
2 cos(a) cos(b) = cos(a - b) + cos(a + b)                      (7c)
Multiple Angle and Powers Formula
sin(2 a) = 2 sin(a)  cos(a)                        (8)
cos(2 a) = cos2(a) - sin2(a)                        (8b)
cos(2 a) = 2 cos2(a) - 1                          (8c)
cos(2 a) = 1 - 2 sin2(a)                        (8d)
tan(2  a) = 2 tan(a) / (1 - tan2(a))                     (8e)
sin2(a) + cos2(a) = 1                         (8f)
sec2(a) = tan2(a) + 1                         (8g)
Special Triangles
Trigonometric Values
sin(-θd ) = - sin(θd )                     (9a)
sin(90° + θd) = cos(θd)                    (9b)
sin(90° - θd) = cos(θd)                   (9c)
sin(180° + θd) = - sin(θd)                 (9d)
sin(180° - θd) = sin(θd)                   (9e)
sin(270° + θd) = - cos(θd)                   (9f)
sin(270° - θd) = - cos(θd)                (9g)
sin(360° + θd) = sin(θd)                 (9h)
sin(360° - θd) = - sin(θd)              (9h)
cos(-θd) = cos(θd)                       (10a)
cos(90° + θd) = - sin(θd)                 (10b)
cos(90° - θd) = sin(θd)                    (10c)
cos(180° + θd) = - cos(θd)                    (10d)
cos(180° - θd) = - cos(θd)                 (10e)
cos(270° + θd) = sin(θd)                (10f)
cos(270° - θd) = - sin(θd)                    (10g)
cos(360° + θd) = cos(θd)                    (10h)
cos(360° - θd) = cos(θd)                   (10h)
tan(-θd) = - tan(θd)                        (11a)
tan(90° + θd) = - cot(θd)                   (11b)
tan(90° - θd) = cot(θd)                        (11c)
tan(180° + θd) = tan(θd)                  (11d)
tan(180° - θd) = - tan(θd)                  (11e)
tan(270° + θd) = - cot(θd)                   (11f)
tan(270° - θd) = cot(θd)                    (11g)
tan(360° + θd) = tan(θd)                    (11h)
tan(360° - θd) = - tan(θd)                     (11h)
Trigometric Functions of Common Angles
30°45°60°90°
Sin 0 1 / 2 √2 / 2 √3 / 2 1
Cos 1 √2 / 2 √2 / 2 1 / 2 0
Tan 0 √3 / 3 1 √3
Cot √3 1 √3 / 3 0
Sec 1 2 √3 / 3 √2 2
Cosec 2 √2 2 √3 / 3 1
Basics
Mathematics
Algebraic Expressions
Principal algebraic expressions formulas.
Angle Converter
Converting between angle units.
Centroids of Plane Areas
The controid of square, rectangle, circle, semi-circle and right-angled triangle.
Complex Numbers
Complex numbers are used in alternating current theory and mechanical vector analysis.
Fractions
Law of fractions
Geometric Shapes - Areas
Areas, diagonals and more - of geometric figures like rectangles, triangles, trapezoids ..
Hyperbolic Functions
Exponential functions related to the hyperbola.
Law of Cosines
One side of a triangle when the opposite angle and two sides are known.
Law of Tangents
Triangles and law of tangents.
Laws of Indices
Simplifying calculations by involving indices.
Logarithms
The rules of logarithms - log10 and loge for numbers ranging 1 to 1000.
Numbers - Squares, Cubes and Roots
Numbers - squares, cubes, square roots and cube roots.
Oblique Triangle
Calculate oblique triangles.
Pythagorean Theorem
Verifying square corners.
Radians vs. Degrees - Definition and Conversions
Right Angled Triangle
Right angled triangle equations.
Soil - Earth Weight and Composition
Typical weight and composition of soil.
Square and Cube Roots of Numbers – Reference Table
Comprehensive table of square and cube roots for various numbers.
Squaring with Diagonal Measurements
A rectangle is square if the lengths of both diagonals are equal.
Standard Differentials and Integrals
Equations for differentials and integrals.
Taylor Series
Function as an infinite sum of terms.
Vector Addition
Online vector calculator - add vectors with different magnitude and direction - like forces, velocities and more.
