e = 2.7182.... - e constant or Euler's number
Base e logarithm of x can be expressed as
log e (x) = ln (x) = y
System | Log to the base of | Terminology |
log a | a | log to base a |
log 10 = lg | 10 | common log |
log e = ln | e = 2.718281828459.. | natural log |
log 2 = lb | 2 | log to base 2 |
log a (x y) = log a (x) + log a (y) (2)
log a (x / y) = log a (x) - log a (y) (3)
log a (x p ) = p log a (x) (4)
log a (1 / x) = - log a (x) (5)
log a (b) = 1 (6)
log a (1) = 0 (7)
log a (0) = undefined (8)
log a (x < 0) = undefined (9)
log a (x) = log c (x) / log c (a) (10)
log a (x → ∞) = ∞ (11)
log 10 ((5) (6)) = log 10 (5) + log 10 (6)
= 0.6990 + 0.7782
= 1.4772
lg (x) = lg (e) ln (x)
= 0.434294 ln (x) (12)
ln (x) = lg (x) / lg (e)
= 2.302585 lg (x) (13)
lb (x) = 1.442695 ln (x)
= 3.321928 lg (x) (15)
The SI-system, unit converters, physical constants, drawing scales and more.
Principal algebraic expressions formulas.
Values for the negative logarithm of the acid dissociation constant, pKa, of the conjugated acid of amines, diamines and cyclic organic nitrogen compounds, shown together with the molecular structure of the acids.
The mathematical π constants.
The mathematical e constants.
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
The laws of fractional and integer exponents.
The product of all positive integers.
Law of fractions
Values for the negative logarithm of the acid dissociation constant, pKa, of inorganic acids and bases, as well as hydrated metal ions.
Simplifying calculations by involving indices.
Some numerical constants.
Introduction to pH - the acidic and basic (alkaline) definition.
For oxygen containing organic compounds this is given: pKa (the negative logarithm of the acid dissociation constant), molecular structures, molar weights, density and melting and boiling points.
Abbreviations for Use on Drawings and in Text - ANSI Y1.1.
How to solve a quadratic equation.
Doubling of the distance from a noise source reduces the sound pressure level with 6 decibel.
Sine, cosine and tangent - the natural trigonometric functions.
