Decibel
The decibel is a logarithmic unit used to describe the ratio of a signal level - like power, intensity or amplitude - to a reference level.
- the decibel express the level of a value relative to a reference value
Two types of decibel are normally used:
- for power ratios - dB is defined as ten times the logarithm in base 10
- for amplitude ratios - root power quantities - a change in amplitude by a factor of 10 corresponds to 20 dB change in level
Decibel Definition - Power Ratios
The decibel level of a signal can be expressed as
L = 10 log(S / Sref) (1)
L = signal level (decibel, dB)
S = signal - intensity or power level (signal unit)
Sref = reference signal - intensity or power level (signal unit)
Decibel is a dimensionless value of relative ratios. The signal units depends on the nature of the signal - can be W for power.
A decibel is one-tenth of a Bel - named after Alexander Graham Bell, the inventor of the telephone.
Note! - the decibel value of a signal increases with 3 dB if the signal is doubled (L = 10 log(2) = 3).
| dB | Power Ratio (S/Sref) | Amplitude Ratio (A/Aref) |
| -40 | 0.0001 | 0.01 |
| -20 | 0.01 | 0.1 |
| 0 | 1 | 1 |
| 3 | 2 | √2 |
| 6 | 4 | 2 |
| 10 | 10 | 3.162 |
| 20 | 100 | 10 |
If the decibel value and reference level are known the absolute signal level can be calculated by transforming (1) to
S = Sref 10(L / 10) (2)
Decibel Calculator
Example - Lowest Hearable Sound Power
10 -12 W is normally the lowest sound power possible to hear and this value is normally used as the reference power in sound power calculations.
The sound power in decibel from a source with the lowest sound hearable can be calculated as
L = 10 log((10-12 W) / (10-12 W))
= 0 dB
Example - Highest Hearable Sound Power
100 W is almost the highest sound power possible to hear. The sound power in decibel from a source with the highest possible to hear sound power can be calculated as
L = 10 log((100 W) / (0-12 W))
= 140 dB
Example - Sound Power from a Fan
A fan creates 1 W of sound power. The noise level from the fan in decibel can be calculated as
L = 10 log((1 W) / (10-12 W))
= 120 dB
Example - Sound Intensity and Decibel
The difference in decibel between sound intensity 10-8 W/m 2 and sound intensity 10-4 W/m2 (10000 units) can be calculated as
ΔL = 10 log((10-4 W/m2) / (10-12 W/m2)) - 10 log((10-8 W/m2) / (10-12 W/m2))
= 40 dB
Increasing the sound intensity by a factor of
- 10 raises its level by 10 dB
- 100 raises its level by 20 dB
- 1000 raises its level by 30 dB
- 10000 raises its level by 40 dB and so on
Decibel Ratios - Amplitude Ratios
L = 20 log(A / A ref) (3)
A = amplitude level (signal unit)
A ref = amplitude level level (signal unit)
• Acoustics
• Noise and Attenuation
Decibel A, B and C
Logarithms
The rules of logarithms - log10 and loge for numbers ranging 1 to 1000.
Noise generated in Air Ducts
Estimate noise generated by air flow in ducts.
Outdoor Ambient Sound Pressure Levels
Outdoor ambient sound pressure levels (dBA) in rural and urban business and industrial environments with or without limited traffic.
Phonetic Alphabet
The phonetic alphabet used in international aircraft communications.
Scales of Objects
The relative scale of objects.
Signals - Adding Decibels
SIL - the Speech Interference Levels
Background noise frequencies that interferes with speech.
Sound Intensity
Acoustic power of sound per unit area.
Use of Telephones in Noisy Areas
Satisfactory, difficult and impossible noise levels for telephone use in noisy areas.
