Noise generated in Air Ducts
Air flow in ducts generates noise. The noise in the duct is determined by
  • air velocity
  • duct size (cross sectional area)
Generated noise can be calculated with the empirical equation
LN = 10 + 50 log (v) + 10 log (A)                                                       (1)
LN = sound power level in the duct (dB)
v = air velocity (m/s)
A = air duct cross sectional area (m2)
The equation modified for imperial units
LN = 10 + 50 log (vi / 197) + 10 log (Ai / 1550)                                                      (1b)
vi = air velocity (ft/min)
Ai = cross sectional area (in2)
Example - Generated Noise in Duct by Air Flow
The cross section area of a 200 mm duct can be calculated as
A = π ((0.2 m) / 2)2)
   = 0.0314  m2
The noise generated in the duct with an air flow velocity 10 m/s can be calculated as
 LN = 10 + 50 log (10 m/s) + 10 log (0.0314 m2)
    = 45 db
The noise generated in the same 200 mm circular duct as above with air flow velocity 20 m/s can be calculated as
 LN = 10 + 50 log (20 m/s) + 10 log (π ((0.2 m) / 2)2)
    = 60 db
Note! - due to the noise generated by fans - noise generated inside ducts by air flow can in general be neglected.
Acoustics
Room acoustics and acoustic properties, decibel A, B and C, Noise Rating (NR) curves, sound transmission, sound pressure, sound intensity and sound attenuation.
Noise and Attenuation
Decibel
Logarithmic unit used to describe ratios of signal levels - like power or intensity - to a reference level.
Ductwork - Seal Classes
Ductwork air leakage classes.
Fans - Noise Power Generation
Noise Attenuation in Rotary Heat Exchanges
Sound attenuation vs. frequency in rotating heat exchangers.
Signals - Adding Decibels
Velocity Classification of Ventilation Ducts
Recommended air velocities in ventilation ducts
