Ducts - Cross-Sectional Area vs. Diameter
Circular ventilation ducts and cross-sectional areas - Imperial Units
Ducts - Cross-Sectional Area vs. Diameter - Imperial Units
Duct Diameter Area
(in)(mm)(ft2)(m2)
8 203 0.3491 0.032
10 254 0.5454 0.051
12 305 0.7854 0.073
14 356 1.069 0.099
16 406 1.396 0.130
18 457 1.767 0.164
20 508 2.182 0.203
22 559 2.640 0.245
24 609 3.142 0.292
26 660 3.687 0.342
28 711 4.276 0.397
30 762 4.900 0.455
32 813 5.585 0.519
34 864 6.305 0.586
36 914 7.069 0.657
Circular ventilation ducts and cross-sectional areas - Metric Units
Ducts - Cross-Sectional Area vs. Diameter - SI Units
Duct DiameterArea
(mm)(m2)(mm2)(in2)
63 0.003 3019 4.7
80 0.005 4902 7.6
100 0.008 7698 11.9
125 0.012 12076 18.7
160 0.020 19856 30.8
200 0.031 31103 48.2
250 0.049 48695 75.5
315 0.077 77437 120
400 0.125 125036 194
500 0.196 195565 303
630 0.311 310736 482
800 0.501 501399 777
1000 0.784 783828 1215
1250 1.225 1225222 1899
Download and print Circular Air Ducts Cross Sectional Area chart.
Ventilation
Circular Ducts - Dimensions
Standard size of circular ventilation air ducts.
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Equivalent Diameter - Rectangular vs. Circular HVAC Ducts
Rectangular equivalent diameter for air flows between 100 - 50000 cfm.
Convert rectangular and oval duct geometry to a equivalent circular diameter - online calculator with imperial and SI-units.
Fluid Flow - Hydraulic Diameter
Calculate hydraulic diameter for pipes and ducts.
Rectangular Ducts - Dimensions
Commonly used metric dimensions for rectangular air ducts in ventilation systems.
