Duct Velocity
Air Duct Velocity - Imperial Units
Air velocity in a ventilation duct can be calculated in imperial units as
v i = q i / A i
= q i / [ π (d f / 2) 2 )]
= q i / [ π ((d i / 12) / 2) 2 )]
= (576 / π) ( q i / d i 2 )
= 144 q i / (a i b i )                                   (1)
v i = air velocity (ft/min)
q i = air flow (ft 3 /min)
A i = area of duct (ft 2 )
d f = diameter of duct (ft)
d i = diameter of duct (in)
a i = width of duct (in)
b i = width of duct (in)
Example - Air Flow Velocity in a Duct
The velocity in a 12 inch duct with air flow 1000 cfm can be calculated as
v i = (576 / π )  (1000 cfm) / (12 in) 2 )
= 1273 (ft/min)
Air Flow Velocity Calculator - Imperial Units
Air velocity can be calculated with the calculator below. Add air volume - q - and diameter - d - (or length a and b ).
or alternatively
- free apps for offline use on mobile devices
Air Duct Velocity - SI Units
Air velocity in a duct can be calculated in SI units
v m = q m / A m
= q m / (π (d m / 2) 2 )
= 4 q m / (π d m 2 )
= q m / (a m b m )                                  (2)
v m = air velocity (m/s)
q m = air flow (m 3 /s)
A m = area of duct (m 2 )
d m = diameter of duct (m)
a m = width of duct (m)
b m = width of duct (m)
The velocity in a rectangular 0.5 m x 0.5 m duct with air flow 1 m 3 /s can be calculated as
v m = (1 m 3 /s) / ((0.5 m) (0.5 m))
= 4 (m/s)
Air Flow Velocity Calculator - SI Units
or alternatively
Air Ducts - Velocity Diagram
The chart below can be used to estimate velocities in air ducts.
The default values are for air flow 400 cfm (680 m 3 /h) , duct size 8 in (200 mm) and velocity 1150 fpm (5.8 m/s) .
Download and print Air Ducts - Velocity Diagram!
Air Ducts Friction Loss
Ventilation
Air Duct Velocities
Typical air duct velocities in applications like ventilation systems or compressed air systems.
A major friction loss diagram for air ducts - SI units.
Air Ducts - Major Friction Head Loss, Online Calculator
Head loss or major loss in air ducts - equations and online calculator for rectangular and circular ducts - Imperial and SI units.
Air Ducts - Sizing
Required duct area vs. air flow.
Air flow volume, duct size, velocity and dynamic pressure.
Circular Ducts - Dimensions
Standard size of circular ventilation air ducts.
Colebrook Equation
The equal friction method for sizing air ducts is easy and straightforward to use.
Ducts - Cross-Sectional Area vs. Diameter
Circular ducts sross-sectional areas.
Ducts - Sheet Metal Gauges
Thickness of sheet metal used in ductwork.
Ducts or Pipes through Steel Joists - Maximum Sizes
Maximum sizes of ducts or pipes through K series joists.
Ductwork - Seal Classes
Ductwork air leakage classes.
Exhaust Outlets - Capturing Air Velocities
Capturing air velocity in front of an exhaust outlet - online exhaust outlet velocity calculator.
Fluid Flow - Hydraulic Diameter
Calculate hydraulic diameter for pipes and ducts.
HVAC Ducts - Air Velocities
Recommended air velocities in HVAC ducts.
Sizing Circular Ducts
A rough guide to maximum air volume capacity of circular ducts in comfort, industrial and high speed ventilation systems.
Spiral Ducts - Dimensions
Standard dimensions of spiral ducts - Imperial units.
Velocity Classification of Ventilation Ducts
Recommended air velocities in ventilation ducts
Velocity Units Converter
Convert between speed and velocity units like m/s, km/h, knots, mph and ft/s.
