Spiral Ducts - Dimensions
Physical properties of spiral pipe - imperial units - are indicated below.
Nominal DiameterOutside DiameterWall ThicknessWeight
(in)(in)(in)(lb/ft)
3 3 0.0276 1.1
4 4 0.0276 1.4
5 5 0.0276 1.7
6 6 0.0276 2.0
7 7 0.0276 2.4
8 8 0.0276 2.8
9 9 0.0276 3.1
10 10 0.0276 3.4
11 11 0.0276 3.8
12 12 0.0276 4.1
13 13 0.0276 4.5
14 14 0.0276 4.8
15 15 0.0276 5.1
16 16 0.0276 5.5
17 17 0.0276 5.8
18 18 0.0276 6.1
20 20 0.0276 6.8
22 22 0.0336 9.1
24 24 0.0336 9.9
26 26 0.0336 10.8
28 28 0.0336 11.6
30 30 0.0336 12.4
32 32 0.0336 13.3
34 34 0.0336 14.1
36 36 0.0336 14.9
38 38 0.0396 18.5
40 40 0.0396 19.5
42 42 0.0396 20.5
44 44 0.0396 21.5
46 46 0.0396 22.5
48 48 0.0396 23.4
50 50 0.0516 32.4
52 52 0.0516 33.7
54 54 0.0516 35.0
56 56 0.0516 36.3
58 58 0.0516 37.6
60 60 0.0516 38.8
62 62 0.0516 41.1
64 64 0.0516 43.4
66 66 0.0516 44.7
68 68 0.0516 46.1
70 70 0.0516 47.4
72 72 0.0516 48.8
Ventilation
Air Ducts - Major Friction Head Loss, Online Calculator
Head loss or major loss in air ducts - equations and online calculator for rectangular and circular ducts - Imperial and SI units.
Circular Ducts - Dimensions
Standard size of circular ventilation air ducts.
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Ducts or Pipes through Steel Joists - Maximum Sizes
Maximum sizes of ducts or pipes through K series joists.
Equivalent Diameter - Rectangular vs. Circular HVAC Ducts
Rectangular equivalent diameter for air flows between 100 - 50000 cfm.
HVAC Ducts - Air Velocities
Recommended air velocities in HVAC ducts.
