Ducts or Pipes through Steel Joists - Maximum Sizes
Maximum duct or pipe sizes through steel joists of K type:
Maximum Duct or Pipe Sizes through Steel Joists of K type
Joists Dept
(in)
Duct or Pipe Size
Round
(in)
Square
(in)
Rectangular
(in)
8 5 4 x 4 3 x 8
10 6 5 x 5 3 x 8
12 7 6 x 6 4 x 9
14 8 6 x 6 4 x 9
16 9 7 x 7 6 x 10
18 11 8 x 8 7 x 11
20 11 9 x 9 7 x 12
22 12 9 x 9 8 x 12
24 13 10 x 10 8 x 13
K series are common open web joists, standard sized for typical applications. K types span from 8’ to 60’ across with depths of 8” to 30”.
Beams and Columns
HVAC Systems
Heating, ventilation and air conditioning systems - design and dimensions.
Air Ducts - Sizing
Required duct area vs. air flow.
Circular Ducts - Dimensions
Standard size of circular ventilation air ducts.
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Equivalent Diameter - Rectangular vs. Circular HVAC Ducts
Rectangular equivalent diameter for air flows between 100 - 50000 cfm.
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
Rectangular Ducts - Dimensions
Commonly used metric dimensions for rectangular air ducts in ventilation systems.
Spiral Ducts - Dimensions
Standard dimensions of spiral ducts - Imperial units.
