Rectangular Ducts - Dimensions
Commonly used rectangular duct sizes in air handling ventilation systems:
Width (mm) | Height (mm) | ||||||||||
100 | 150 | 200 | 250 | 300 | 400 | 500 | 600 | 800 | 1000 | 1200 | |
200 | 1) | 1) | 2) | 3) | 3) | 3) | 3) | 3) | 3) | 3) | 3) |
250 | 2) | 2) | 2) | 2) | 3) | 3) | 3) | 3) | 3) | 3) | 3) |
300 | 1) | 1) | 1) | 2) | 2) | 3) | 3) | 3) | 3) | 3) | 3) |
400 | 1) | 1) | 1) | 2) | 1) | 2) | 3) | 3) | 3) | 3) | 3) |
500 | 3) | 1) | 1) | 2) | 1) | 1) | 2) | 3) | 3) | 3) | 3) |
600 | 3) | 1) | 1) | 2) | 1) | 1) | 1) | 2) | 3) | 3) | 3) |
800 | 3) | 3) | 1) | 2) | 1) | 1) | 1) | 1) | 2) | 3) | 3) |
1000 | 3) | 3) | 3) | 2) | 1) | 1) | 1) | 1) | 1) | 2) | 3) |
1200 | 3) | 3) | 3) | 3) | 1) | 1) | 1) | 1) | 1) | 1) | 2) |
1400 | 3) | 3) | 3) | 3) | 3) | 2) | 2) | 2) | 2) | 2) | 2) |
1600 | 3) | 3) | 3) | 3) | 3) | 1) | 1) | 1) | 1) | 1) | 1) |
1800 | 3) | 3) | 3) | 3) | 3) | 3) | 2) | 2) | 2) | 2) | 2) |
2000 | 3) | 3) | 3) | 3) | 3) | 3) | 3) | 3) | 1) | 1) | 1) |
1) Preferred, 2) Acceptable, 3) Not common
• Ventilation Systems
The equal friction method for sizing air ducts is easy and straightforward to use.
Ducts - Cross-Sectional Area vs. Diameter
Circular ducts sross-sectional areas.
Ducts or Pipes through Steel Joists - Maximum Sizes
Maximum sizes of ducts or pipes through K series joists.
Equivalent Diameter - Rectangular vs. Circular HVAC Ducts
Rectangular equivalent diameter for air flows between 100 - 50000 cfm.
Convert rectangular and oval duct geometry to a equivalent circular diameter - online calculator with imperial and SI-units.
Rectangular Air Ducts - Velocity Diagram
Velocity diagram for rectangular air ducts - metric units.
