Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
Condensate Generated in Cold Steam Pipes - SI Units
Huge amounts of condensate are generated when cold steam pipes are heated up must be drained from the pipes.
Condensate Generated in Cold Steam Pipes - Sizing of Steam Traps
When cold steam pipes are heated up they generate huge amounts of condensate that must be drained away from the pipe through steam traps - in Imperial Units.
Convective Heat Transfer
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Heat Transfer Coefficients in Heat Exchanger Surface Combinations
Insulated Steam Pipes - Condensate Generated
Heat loss from steam pipes generates condensate which must be drained from the system - imperial units.
Insulated Steam Pipes - Condensate Generated (kg/h per 100m)
Heat loss from steam pipes generates condensate which must be drained from the system.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Oil Filled Tanks - Heat Loss
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Overall Heat Transfer Coefficients
Perlite Insulation
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Radiation - Surface Emissivity Coefficients
Radiation emissivity of common materials like water, ice, snow, grass and more.
Radiation Heat Transfer
Steam Heating Systems - Classifications
Steam systems carries heat through pipes from the boiler to consumers as heat exchangers, process equipment etc.
Steam Pipes - Fuel Consumption due to Heat Losses over a Year
Yearly heat loss in amount of coal or oil consumption for insulated and uninsulated steam pipes at different dimensions and operation times.
Steam Pipes - Heat Losses
The amount of condensate generated in a steam pipe depends on the heat loss from the pipe to the surroundings.
Steam Pipes - Heat Losses (W/m)
Heat losses from un-insulated steam pipes.
Steam Tracing Pipe Lines
Steam tracing of pipe lines can be done to maintain appropriate product temperatures.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
