Pipes Submerged in Oil or Fat - Heat Emission
The viscosity of a fluid has considerable influence on the heat transfered from a submerged heating pipe. Be aware that the viscosity of a fluid is highly dependent on the temperature.
Heat emission from steam pipes submerged in oil baths are indicated below:
Application | Fluid | Heat Emission from coil surface | |
(Btu/ft2 hr oF) | (W/m2 oC) | ||
Steam coil with medium steam pressure and natural convection of oil | Light Oils | 30 | 170 |
Heavy Oils | 15 - 20 | 85 - 115 | |
Fats | 5 - 10 | 30 - 60 | |
Steam coil with medium pressure and forced convection of oil | Light Oils | 100 | 570 |
Heavy Oils | 60 | 340 | |
Fats | 30 | 170 |
- Light oils - 220 SSU at 100 oF
- Heavy oils - 1100 SSU at 100 oF
- Fats - 3833 SSU at 100 oF
- Carbon, Alloy and Stainless Steel Pipes - ASME/ANSI B36.10/19 - dimensions
- Outside surface area - pipe equations
Example - Heat Emission from a 2" Coil in a Fat Tank
A 10 m long 2" inch stainless steel steam coil heats a tank with fat. The steam pressure is 1 bar and the temperature in the coil is 120 oC. The temperature in the tank is 40 oC. The convection is natural with heat emission 50 W/m2oC.
The outside diameter of the pipe is 60.3 mm and the external surface of the pipe pr. m length of pipe can be calculated as
As = 2 π ((0.063 m) / 2) (1 m)
= 0.2 m2/m pipe
The heat emission from the coil as whole can be calculated as
Q = (10 m) (0.2 m2/m pipe) (50 W/m2oC) ((120 oC) - (40 oC))
= 8000 W
= 8 kW
• Heating Systems
• Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
• Steam and Condensate
Food and Foodstuff - Specific Heat
Specific heat of common food and foodstuff like apples, bass, beef, pork and many more.
Heat Loss from Oil Filled Tanks and Pipe Lines
Heat loss from insulated and non insulated sheltered and exposed oil tanks and pipes.
Oil Filled Tanks - Heat Loss
Heat loss from insulated and uninsulated, sheltered and exposed heated oil tanks.
Oil Tanks - Heat Loss
Heat loss from lagged and unlagged, sheltered and exposed oil tanks.
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Specific Heat of Common Liquids and Fluids
Specific Heat of Common Materials – Engineering Reference
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
Submerged Coils - Heat Transfer Coefficients
Heat transfer coefficients for steam and hot water coils submerged in oil tanks.
