ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
The steel pipe data chart below can be used to find pipe sizes, diameters, wall thickness, working pressures and more The chart is based on ASME/ANSI B 36.10 Welded and Seamless Wrought Steel Pipe and ASME/ANSI B36.19 Stainless Steel Pipe.
Regardless of schedule number, pipes of a particular size all have the same outside diameter (not withstanding manufacturing tolerances). As the schedule number increases, the wall thickness increases, and the actual bore is reduced. For example:
- A 4 inches (100 mm) Schedule 40 pipe has an outside diameter of 4.500 inches (114.30 mm), a wall thickness of 0.237 inches (6.02 mm), giving a bore of 4.026 inches (102.26 mm)
- A 4 inches (100 mm) Schedule 80 pipe has an outside diameter of 4.500 inches ( 114.30 mm), a wall thickness of 0.337 inches (8.56 mm), giving a bore of 3.826 inches (97.18 mm)
Outside Diameter, Identification, Wall Thickness, Inside Diameter
Pipe Size (inches) | Outside Diameter (inches) | Identification | Wall Thickness - t - (inches) | Inside Diameter - d - (inches) | ||
Steel | Stainless Steel Schedule No. | |||||
Iron Pipe Size | Schedule No. | |||||
1/8 | 0.405 | . STD XS |
. 40 80 |
10S 40S 80S |
0.049 0.068 0.095 |
0.307 0.269 0.215 |
1/4 | 0.540 | . STD XS |
. 40 80 |
10S 40S 80S |
0.065 0.088 0.119 |
0.410 0.364 0.302 |
3/8 | 0.675 | . STD XS |
. 40 80 |
10S 40S 80S |
0.065 0.091 0.126 |
0.545 0.493 0.423 |
1/2 | 0.840 | . . STD XS . XXS |
. . 40 80 160 . |
5S 10S 40S 80S . . |
0.065 0.083 0.109 0.147 0.187 0.294 |
0.710 0.674 0.622 0.546 0.466 0.252 |
3/4 | 1.050 |
. . STD XS . XXS |
. . 40 80 160 . |
0.065 0.083 0.113 0.154 0.219 0.308 |
0.920 0.884 0.824 0.742 0.612 0.434 |
1 | 1.315 | . . STD XS . XXS |
. . 40 80 160 . |
0.065 0.109 0.133 0.179 0.250 0.358 |
1.185 1.097 1.049 0.957 0.815 0.599 |
1 1/4 | 1.660 | . . STD XS . XXS |
. . 40 80 160 . |
0.065 0.109 0.140 0.191 0.250 0.382 |
1.530 1.442 1.380 1.278 1.160 0.896 |
1 1/2 | 1.900 | . . STD XS . XXS |
. . 40 80 160 . |
0.065 0.109 0.145 0.200 0.281 0.400 |
1.770 1.682 1.610 1.500 1.338 1.100 |
2 | 2.375 | . . STD XS . XXS |
. . 40 80 160 . |
0.065 0.109 0.154 0.218 0.344 0.436 |
2.245 2.157 2.067 1.939 1.687 1.503 |
2 1/2 | 2.875 | . . STD XS . XXS |
. . 40 80 160 . |
0.083 0.120 0.203 0.276 0.375 0.552 |
2.709 2.635 2.469 2.323 2.125 1.771 |
3 | 3.500 | . . STD XS . XXS |
. . 40 80 160 . |
0.083 0.120 0.216 0.300 0.438 0.600 |
3.334 3.260 3.068 2.900 2.624 2.300 |
3 1/2 | 4.000 | . . STD XS |
. . 40 80 |
5S 10S 40S 80S |
0.083 0.120 0.226 0.318 |
3.834 3.760 3.548 3.364 |
4 | 4.500 | . . STD XS . . XXS |
. . 40 80 120 160 . |
5S 10S 40S 80S . . . |
0.083 0.120 0.237 0.337 0.438 0.531 0.674 |
4.334 4.260 4.026 3.826 3.624 3.438 3.152 |
5 | 5.563 | . . STD XS . . XXS |
0.109 0.134 0.258 0.375 0.500 0.625 0.750 |
5.345 5.295 5.047 4.813 4.563 4.313 4.063 |
6 | 6.625 | . . STD XS . . XXS |
0.109 0.134 0.280 0.432 0.562 0.718 0.864 |
6.407 6.357 6.065 5.761 5.501 5.189 4.897 |
8 | 8.625 | . . . . STD . XS . . . XXS . |
. . 20 30 40 60 80 100 120 140 . 160 |
5S 10S . . 40S . 80S . . . . . |
0.109 0.148 0.250 0.277 0.322 0.406 0.500 0.594 0.719 0.812 0.875 0.906 |
8.407 8.329 8.125 8.071 7.981 7.813 7.625 7.437 7.187 7.001 6.875 6.813 |
10 | 10.750 | . . . . STD XS . . . . . |
. . 20 30 40 60 80 100 120 140 160 |
5S 10S . . 40S 80S . . . . . |
0.134 0.165 0.250 0.307 0.365 0.500 0.594 0.719 0.844 1.000 1.125 |
10.482 10.420 10.250 10.136 10.020 9.750 9.562 9.312 9.062 8.750 8.500 |
12 | 12.75 | . . . . STD . XS . . . . . . |
. . 20 30 . 40 . 60 80 100 120 140 160 |
5S 10S . . 40S . 80S . . . . . . |
0.156 0.180 0.25 0.330 0.375 0.406 0.500 0.562 0.688 0.844 1.000 1.125 1.312 |
12.438 12.390 12.250 12.090 12.000 11.938 11.750 11.626 11.374 11.062 10.750 10.500 10.126 |
14 | 14.00 | . . . . STD . XS . . . . . .. |
. . 10 20 30 40 . 60 80 100 120 140 160 |
5S 10S . . . . . . . . . . . |
0.156 0.188 0.250 0.312 0.375 0.438 0.500 0.594 0.750 0.938 1.094 1.250 1.406 |
13.688 13.624 13.500 13.376 13.250 13.124 13.000 12.812 12.500 12.124 11.812 11.500 11.188 |
16 | 16.00 | . . . . STD XS . . . . . . |
. . 10 20 30 40 60 80 100 120 140 160 |
5S 10S . . . . . . . . . . |
0.165 0.188 0.250 0.312 0.375 0.500 0.656 0.844 1.031 1.219 1.438 1.594 |
15.670 15.624 15.500 15.376 15.250 15.000 14.688 14.312 13.938 13.562 13.124 12.812 |
18 | 18.00 | . . . . STD . XS . . . . . . . |
. . 10 20 . 30 . 40 60 80 100 120 140 160 |
5S 10S . . . . . . . . . . . . |
0.165 0.188 0.250 0.312 0.375 0.438 0.500 0.562 0.750 0.938 1.156 1.375 1.562 1.781 |
17.670 17.624 17.500 17.376 17.250 17.124 17.000 16.876 16.500 16.124 15.688 15.250 14.876 14.438 |
- 1 in (inch) = 25.4 mm
Area of Metal, Transverse Internal Area, Moment of Inertia, Weight Pipe, Weight Water, External Surface, Elastic Section Modulus
For full table with External Surface and Elastic Section Modulus - rotate the screen!
Pipe Size (inches) | Area of Metal (square inches) | Transverse Internal Area | Area Moment of Inertia - l - (inches4) | Weight Pipe (pounds per foot) | Weight Water (pounds per foot) | External Surface (square feet per foot of pipe) | Elastic Section Modulus - S - (in3) | |
- a - (square inches) | - A - (square feet) | |||||||
1/8 | 0.0548 0.0720 0.0925 |
0.0740 0.0568 0.0364 |
0.00051 0.00040 0.00025 |
0.00088 0.00106 0.00122 |
0.19 0.24 0.31 |
0.032 0.025 0.016 |
0.106 0.106 0.106 |
0.00437 0.00523 0.00602 |
1/4 | 0.0970 0.1250 0.1574 |
0.1320 0.1041 0.0716 |
0.00091 0.00072 0.00050 |
0.00279 0.00331 0.00377 |
0.33 0.42 0.54 |
0.057 0.045 0.031 |
0.141 0.141 0.141 |
0.01032 0.01227 0.01395 |
3/8 | 0.1246 0.1670 0.2173 |
0.2333 0.1910 0.1405 |
0.00162 0.00133 0.00098 |
0.00586 0.00729 0.00862 |
0.42 0.57 0.74 |
0.101 0.083 0.061 |
0.178 0.178 0.178 |
0.01736 0.02160 0.02554 |
1/2 | 0.1583 0.1974 0.2503 0.3200 0.3836 0.5043 |
0.3959 0.3568 0.3040 0.2340 0.1706 0.050 |
0.00275 0.00248 0.00211 0.00163 0.00118 0.00035 |
0.01197 0.01431 0.01709 0.02008 0.02212 0.02424 |
0.54 0.67 0.85 1.09 1.31 1.71 |
0.172 0.155 0.132 0.102 0.074 0.022 |
0.220 0.220 220 0.220 220 0.220 |
0.02849 0.03407 0.04069 0.04780 0.05267 0.05772 |
3/4 | 0.2011 0.2521 0.3326 0.4335 0.5698 0.7180 |
0.6648 0.6138 0.5330 0.4330 0.2961 0.148 |
0.00462 0.00426 0.00371 0.00300 0.00206 0.00103 |
0.02450 0.02969 0.03704 0.04479 0.05269 0.05792 |
0.69 0.86 1.13 1.47 1.94 2.44 |
0.288 0.266 0.231 0.188 0.128 0.064 |
0.275 0.275 0.275 0.275 0.275 0.275 |
0.04667 0.05655 0.07055 0.08531 0.10036 0.11032 |
1 | 0.2553 0.4130 0.4939 0.6388 0.8365 1.0760 |
1.1029 0.9452 0.8640 0.7190 0.5217 0.282 |
0.00766 0.00656 0.00600 0.00499 0.00362 0.00196 |
0.04999 0.07569 0.08734 0.1056 0.1251 0.1405 |
0.87 1.40 1.68 2.17 2.84 3.66 |
0.478 0.409 0.375 0.312 0.230 0.122 |
0.344 0.344 0.344 0.344 0.344 0.344 |
0.07603 0.11512 0.1328 0.1606 0.1903 0.2136 |
1 1/4 | 0.3257 0.4717 0.6685 0.8815 1.1070 1.534 |
1.839 1.633 1.495 1.283 1.057 0.630 |
0.01277 0.01134 0.01040 0.00891 0.00734 0.00438 |
0.1038 0.1605 0.1947 0.2418 0.2839 0.3411 |
1.11 1.81 2.27 3.00 3.76 5.21 |
0.797 0.708 0.649 0.555 0.458 0.273 |
0.435 0.435 0.435 0.435 0.435 0.435 |
0.1250 0.1934 0.2346 0.2913 0.3421 0.4110 |
1 1/2 | 0.3747 0.6133 0.7995 1.068 1.429 1.885 |
2.461 2.222 2.036 1.767 1.406 0.950 |
0.01709 0.01543 0.01414 0.01225 0.00976 0.00660 |
0.1579 0.2468 0.3099 0.3912 0.4824 0.5678 |
1.28 2.09 2.72 3.63 4.86 6.41 |
1.066 0.963 0.882 0.765 0.608 0.42 |
0.497 0.497 0.497 0.497 0.497 0.497 |
0.1662 0.2598 0.3262 0.4118 0.5078 0.5977 |
2 | 0.4717 0.7760 1.075 1.477 2.190 2.656 |
3.958 3.654 3.355 2.953 2.241 1.774 |
0.02749 0.02538 0.02330 0.02050 0.01556 0.01232 |
0.3149 0.4992 0.6657 0.8679 1.162 1.311 |
1.61 2.64 3.65 5.02 7.46 9.03 |
1.72 1.58 1.45 1.28 0.97 0.77 |
0.622 0.622 0.622 0.622 0.622 0.622 |
0.2652 0.4204 0.5606 0.7309 0.979 1.104 |
2 1/2 | 0.7280 1.039 1.704 2.254 2.945 4.028 |
5.764 5.453 4.788 4.238 3.546 2.464 |
0.04002 0.03787 0.03322 0.02942 0.02463 0.01710 |
0.7100 0.9873 1.530 1.924 2.353 2.871 |
2.48 3.53 5.79 7.66 10.01 13.69 |
2.50 2.36 2.07 1.87 1.54 1.07 |
0.753 0.753 0.753 0.753 0.753 0.753 |
0.4939 0.6868 1.064 1.339 1.638 1.997 |
3 | 0.8910 1.274 2.228 3.016 4.205 5.466 |
8.730 8.347 7.393 6.605 5.408 4.155 |
0.06063 0.05796 0.05130 0.04587 0.03755 0.02885 |
1.301 1.822 3.017 3.894 5.032 5.993 |
3.03 4.33 7.58 10.25 14.32 18.58 |
3.78 3.62 3.20 2.6 2.35 1.80 |
0.916 0.916 0.916 0.916 0.916 0.916 |
0.7435 1.041 1.724 2.225 2.876 3.424 |
3 1/2 | 1.021 1.463 2.680 3.678 |
11.545 11.104 9.886 8.888 |
0.08017 0.07711 0.06870 0.06170 |
1.960 2.755 4.788 6.280 |
3.48 4.97 9.11 12.50 |
5.00 4.81 4.29 3.84 |
1.047 1.047 1.047 1.047 |
0.9799 1.378 2.394 3.140 |
4 | 1.152 1.651 3.174 4.407 5.595 6.621 8.101 |
14.75 14.25 12.73 11.50 10.31 9.28 7.80 |
0.10245 0.09898 0.08840 0.07986 0.0716 0.0645 0.0542 |
2.810 3.963 7.233 9.610 11.65 13.27 15.28 |
3.92 5.61 10.79 14.98 19.0 22.51 27.54 |
6.39 6.18 5.50 4.98 4.47 4.02 3.38 |
1.178 1.178 1.178 1.178 1.178 1.178 1.178 |
1.249 1.761 3.214 4.271 5.178 5.898 6.791 |
5 | 1.868 2.285 4.300 6.112 7.953 9.696 11.340 |
22.44 22.02 20.01 18.19 16.35 14.61 12.97 |
0.1558 0.1529 0.1390 0.1263 0.1136 0.1015 0.0901 |
6.947 8.425 15.16 20.67 25.73 30.03 33.63 |
6.36 7.77 14.62 20.78 27.04 32.96 38.55 |
9.72 9.54 8.67 7.88 7.09 6.33 5.61 |
1.456 1.456 1.456 1.456 1.456 1.456 1.456 |
2.498 3.029 5.451 7.431 9.250 10.796 12.090 |
6 | 2.231 2.733 5.581 8.405 10.70 13.32 15.64 |
32.24 31.74 28.89 26.07 23.77 21.15 18.84 |
0.2239 0.2204 0.2006 0.1810 0.1650 0.1469 0.1308 |
11.85 14.40 28.14 40.49 49.61 58.97 66.33 |
7.60 9.29 18.97 28.57 36.39 45.35 53.16 |
13.97 13.75 12.51 11.29 10.30 9.16 8.16 |
1.734 1.734 1.734 1.734 1.734 1.734 1.734 |
3.576 4.346 8.496 12.22 14.98 17.81 20.02 |
8 | 2.916 3.941 6.57 7.26 8.40 10.48 12.76 14.96 17.84 19.93 21.30 21.97 |
55.51 54.48 51.85 51.16 50.03 47.94 45.66 43.46 40.59 38.50 37.12 36.46 |
0.3855 0.3784 0.3601 0.3553 0.3474 0.3329 0.3171 0.3018 0.2819 0.2673 0.2578 0.2532 |
26.44 35.41 57.72 63.35 72.49 88.73 105.7 121.3 140.5 153.7 162.0 165.9 |
9.93 13.40 22.36 24.70 28.55 35.64 43.39 50.95 60.71 67.76 72.42 74.69 |
24.06 23.61 22.47 22.17 21.70 20.77 19.78 18.83 17.59 16.68 16.10 15.80 |
2.258 2.258 2.258 2.258 2.258 2.258 2.258 2.258 2.258 2.258 2.258 2.258 |
6.131 8.212 13.39 14.69 16.81 20.58 24.51 28.14 32.58 35.65 37.56 38.48 |
10 | 4.36 5.49 8.24 10.07 11.90 16.10 18.92 22.63 26.24 30.63 34.02 |
86.29 85.28 82.52 80.69 78.86 74.66 71.84 68.13 64.53 60.13 56.75 |
0.5992 0.5922 0.5731 0.5603 0.5475 0.5185 0.4989 0.4732 0.4481 0.4176 0.3941 |
63.0 76.9 113.7 137.4 160.7 212.0 244.8 286.1 324.2 367.8 399.3 |
15.19 18.65 28.04 34.24 40.48 54.74 64.43 77.03 89.29 104.13 115.64 |
37.39 36.95 35.76 34.96 34.20 32.35 31.13 29.53 27.96 26.06 24.59 |
2.814 2.814 2.814 2.814 2.814 2.814 2.814 2.814 2.814 2.814 2.814 |
11.71 14.30 21.15 25.57 29.90 39.43 45.54 53.22 60.32 68.43 74.29 |
12 | 6.17 7.11 9.82 12.87 14.58 15.77 19.24 21.52 26.03 31.53 36.91 41.08 47.14 |
121.50 120.57 117.86 114.80 113.10 111.93 108.43 106.16 101.64 96.14 90.76 86.59 80.53 |
0.8438 0.8373 0.8185 0.7972 0.7854 0.7773 0.7528 0.7372 0.7058 0.6677 0.6303 0.6013 0.5592 |
122.4 140.4 191.8 248.4 279.3 300.3 361.5 400.4 475.1 561.6 641.6 700.5 781.1 |
20.98 24.17 33.38 43.77 49.56 53.52 65.42 73.15 88.63 107.32 125.49 139.67 160.27 |
52.65 52.25 51.07 49.74 49.00 48.50 46.92 46.00 44.04 41.66 39.33 37.52 34.89 |
3.338 3.338 3.338 3.338 3.338 3.338 3.338 3.338 3.338 3.338 3.338 3.338 3.338 |
19.2 22.0 30.2 39.0 43.8 47.1 56.7 62.8 74.6 88.1 100.7 109.9 122.6 |
14 | 6.78 8.16 10.80 13.42 16.05 18.66 21.21 24.98 31.22 38.45 44.32 50.07 55.63 |
147.15 145.78 143.14 140.52 137.88 135.28 132.73 128.96 122.72 115.49 109.62 103.87 98.31 |
1.0219 1.0124 0.9940 0.9758 0.9575 0.9394 0.9217 0.8956 0.8522 0.8020 0.7612 0.7213 0.6827 |
162.6 194.6 255.3 314.4 372.8 429.1 483.8 562.3 678.3 824.4 929.6 1027.0 1117.0 |
23.07 27.73 36.71 45.61 54.57 63.44 72.09 85.05 106.13 130.85 150.79 170.28 189.11 |
63.77 63.17 62.03 60.89 59.75 58.64 57.46 55.86 53.18 50.04 47.45 45.01 42.60 |
3.665 3.665 3.665 3.665 3.665 3.665 3.665 3.665 3.665 3.665 3.665 3.665 3.665 |
23.2 27.8 36.6 45.0 53.2 61.3 69.1 80.3 98.2 117.8 132.8 146.8 159.6 |
16 | 8.21 9.34 12.37 15.38 18.41 24.35 31.62 40.14 48.48 56.56 65.78 72.10 |
192.85 191.72 188.69 185.69 182.65 176.72 169.44 160.92 152.58 144.50 135.28 128.96 |
1.3393 1.3314 1.3103 1.2895 1.2684 1.2272 1.1766 1.175 1.0596 1.0035 0.9394 0.8956 |
257.3 291.9 383.7 473.2 562.1 731.9 932.4 1155.8 1364.5 1555.8 1760.3 1893.5 |
27.90 31.75 42.05 52.27 62.58 82.77 107.50 136.61 164.82 192.43 223.64 245.25 |
83.57 83.08 81.74 80.50 79.12 76.58 73.42 69.73 66.12 62.62 58.64 55.83 |
4.189 4.189 4.189 4.189 4.189 4.189 4.189 4.189 4.189 4.189 4.189 4.189 |
32.2 36.5 48.0 59.2 70.3 91.5 116.6 144.5 170.5 194.5 220.0 236.7 |
18 | 9.25 10.52 13.94 17.34 20.76 24.17 27.49 30.79 40.64 50.23 61.17 71.81 80.66 90.75 |
245.22 243.95 240.53 237.13 233.71 230.30 226.98 223.68 213.83 204.24 193.30 182.66 173.80 163.72 |
1.7029 1.6941 1.6703 1.6467 1.6230 1.5990 1.5763 1.5533 1.4849 1.4183 1.3423 1.2684 1.2070 1.1369 |
367.6 417.3 549.1 678.2 806.7 930.3 1053.2 1171.5 1514.7 1833.0 2180.0 2498.1 2749.0 3020.0 |
31.43 35.76 47.39 58.94 70.59 82.15 93.45 104.67 138.17 170.92 207.96 244.14 274.22 308.50 |
106.26 105.71 104.21 102.77 101.18 99.84 98.27 96.93 92.57 88.50 83.76 79.07 75.32 70.88 |
4.712 4.712 4.712 4.712 4.712 4.712 4.712 4.712 4.712 4.712 4.712 4.712 4.712 4.712 |
40.8 46.4 61.1 75.5 89.6 103.4 117.0 130.1 168.3 203.8 242.3 277.6 305.5 335.6 |
- 1 lbm = 0.4536 kg
- 1 ft (foot) = 0.3048 m
- 1 ft2 = 0.0929 m2
- 1 in2 = 645.2 mm2 = 6.452 cm2 = 6.452×10-4 m2
- 1 cm4 = 10-8 m = 104 mm
- 1 in4 = 4.16×105 mm4 = 41.6 cm4
- 1 in3 = 0.000016387 m3 = 16.38 cm3 = 5.78×10-4 ft3
STD, XS and XXS
To distinguish different weights of pipe, three long standing traditional designations are used:
- standard wall - STD
- extra strong wall - XS
- double extra strong wall - XXS
The last two designations are sometimes referred to as extra heavy wall (XH), and double extra heavy wall (XXH).
• Piping Systems
AISI 310 Stainless Steel - Properties
Thermal diffusivity, specific heat capacity, density and thermal conductivity of stainless steel AISI 310 vs. temperature.
Alloy Steels
Alloy steels have properties due to elements other than carbon.
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 150 to 2500
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - Class 150 to 2500.
ASTM A53 B Carbon Steel Pipes - Allowable Pressure vs. Schedule and Size
Maximum working pressure of carbon steel pipe at temperature 400oF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Metric Units
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
Commercial Pipes Properties
Properties of commercial pipes - metric units.
EN 10241 - Steel Threaded Pipe Fittings
EN 10241 specifies requirements for screw threaded fittings.
EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Dimensions of welded stainless steel tubes according EN 10312.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Hot Water Heating System Online Design Application
Pressure loss nomogram for hot water steel pipes.
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Pipe vs. Tube
Pipes and tubes are not exactly the same
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
Schedule - Terminology
Introduction to the schedule terminology of pipes.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steels - Corrosion Resistance
Corrosion resistanse of AISI stainless steels in various environments.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
Steel Pipes - Bundling Schedules Length and Weight
Bundling schedules for standard weight and extra strong steel pipes.
Steel Pipes - Maximum Water Flow Capacities vs. Size
Maximum water flow capacities in steel pipes - pipe dimensions ranging 2 - 24 inches.
Steel Pipes - Weight
Steel Pipes Schedule 40 - Friction Loss vs. Water Flow Diagram
Friction loss and velocity diagrams - in imperial (psi/100 ft, ft/s) and SI (Pa/100m, m/s) units.
Steel Pipes Schedule 40 - Pressure Loss
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour.
Steel Pipes Schedule 80 - Friction Loss vs. Water Flow Diagram
Water flow in steel pipes schedule 80 - pressure drop and velocity diagrams in SI and Imperial units.
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
Wrought Steel Pipes - Bursting Pressures vs. Size
Theoretical bursting and working pressure of wrought steel standard, extra strong and double extra strong pipes.
