EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Copper tubes dimensions according EN 10312:
Nominal SizesExternal DiameterExternal Diameter ToleranceMinimum Wall ThicknessWall Thickness Tolerance
DNmminchmmmmmmmm
10 12 3/8 12 0.1 1.0 0.10
15 15 0.1 1.0 0.10
15 18 1/2 18 0.1 1.0 0.10
20 22 3/4 22 0.11 1.2 0.10
25 28 1 28 0.14 1.2 0.10
32 35 1 1/4 35 0.18 1.5 0.10
40 42 1 1/2 42 0.21 1.5 0.10
50 54 2 54 0.27 2.0 0.10
65 76.1 2 1/2 76.1 0.38 2.0 0.15
80 88.9 3 88.9 0.44 2.0 0.15
100 108 4 108 0.54 2.0 0.15
Dimensions
ANSI Schedule 40 Steel Pipes - Dimensions
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipes - Dimensions
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Piping Materials - Cost Ratios
Pressfit Piping - Dimensions
Dimension of pressfit pipes.
Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of stainless steel vs. temperature
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
