ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
The A312/A312M-02 Standard Specification for Seamless and Welded Austenitic Stainless Steel Pipes covers seamless, straight-seam welded, and heavily cold worked welded austenitic stainless steel pipe intended for high-temperature and general corrosive service.
Nominal Size
(inches)
Schedule NumberOutside Diameter
(inches)
Wall Thickness
(inches)
Inside Diameter
(inches)
Bursting Internal Pressure
(psi)
Collapsing External Pressure
(psi)
1/8 10 0.405 0.049 0.307 18150 7468
40 0.405 0.068 0.269 25195 10761
80 0.405 0.095 0.215 35185 15441
1/4 10 0.540 0.065 0.410 18055 7425
40 0.540 0.088 0.364 24444 10415
80 0.540 0.119 0.302 33055 14445
3/8 10 0.678 0.065 0.545 14380 5705
40 0.678 0.091 0.493 20132 8397
80 0.678 0.126 0.423 27876 12021
1/2 5 0.840 0.065 0.710 11607 4407
10 0.840 0.083 0.674 14821 5911
40 0.840 0.109 0.622 19464 8084
80 0.840 0.147 0.546 26250 11260
3/4 5 1.050 0.065 0.920 9285 3295
10 1.050 0.083 0.884 11857 4524
40 1.050 0.113 0.824 16142 6529
80 1.050 0.154 0.742 22000 9271
1 5 1.315 0.065 1.185 7414 2445
10 1.315 0.109 1.097 12433 3795
40 1.315 0.133 1.049 15171 6075
80 1.315 0.179 0.957 20418 8530
1 1/4 5 1.660 0.065 1.530 5873 1725
10 1.660 0.109 1.442 9849 3585
40 1.660 0.140 1.380 12650 3895
80 1.660 0.191 1.278 17259 7052
1 1/2 5 1.900 0.065 1.770 5131 1376
10 1.900 0.109 1.682 8605 3002
40 1.900 0.145 1.610 11447 4332
80 1.900 0.200 1.500 15789 6364
2 5 2.375 0.065 2.245 4105 896
10 2.375 0.109 2.157 6884 2196
40 2.375 0.154 2.067 9726 3526
80 2.375 0.218 1.939 13768 5418
2 1/2 5 2.875 0.083 2.709 4330 1001
10 2.875 0.120 2.635 6260 1905
40 2.875 0.203 2.469 10591 3931
3 5 3.500 0.083 3.334 3557 639
10 3.500 0.120 3.260 5142 1375
40 3.500 0.216 3.068 9257 3307
3 1/2 5 4.000 0.083 3.834 3112 431
10 4.000 0.120 3.760 4500 1081
4 5 4.500 0.083 4.334 2766 315
10 4.500 0.120 4.260 4000 845
40 4.500 0.237 4.026 7900 2672
5 5 5.563 0.109 5.345 2949 350
10 5.563 0.134 5.295 3613 665
6 5 6.625 0.109 6.407 2467 129
10 6.625 0.134 6.357 3033 394
Pressure Ratings
American vs. British Piping Standards
US American (ASTM) vs. British (BSi) piping standards - specifications, grades and material descriptions.
ASME 31.3 Piping Materials - Allowable Pressure Calculator
Calculate ASME 31.3 allowable pressure
ASTM International - Standards for Steel Pipes, Tubes and Fittings
The ASTM standards covers various types of steel pipes, tubes and fittings for high-temperature services, ordinary use and special applications such as fire protection use
Barlow's Formula - Calculate Internal, Allowable and Bursting Pressure
Calculate pipes internal, allowable and bursting pressure.
Carbon Steel Flanges - Pressure and Temperature Ratings
Maximum ratings for flanges conforming to ISO Standard 2229 dimensions and material specification AST-A-105.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Metric Units
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Dimensions of welded stainless steel tubes according EN 10312.
Pressfit Piping - Dimensions
Dimension of pressfit pipes.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of stainless steel vs. temperature
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
Stainless Steels - Corrosion Resistance
Corrosion resistanse of AISI stainless steels in various environments.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
Steel Tubes - Working Pressures vs. Size
Normal maximum working pressures for steel tubes - in psi and kPa.
Water Hammer
Rapidly closing or openingĀ valves - or starting stopping pumps - may cause pressure transients in pipelines known as surge or water hammers.
Wrought Steel Pipes - Bursting Pressures vs. Size
Theoretical bursting and working pressure of wrought steel standard, extra strong and double extra strong pipes.
