Wrought Steel Pipes - Bursting Pressures vs. Size
The bursting pressures are based on Barlow's formula. The working pressures are based on factor 8.
Dimensions according ASME/ANSI B36.10/19.
Standard Wrought Steel Pipes - STD - Schedule 40
Wrought Steel Pipes - Standard - STD - Sch. 40 - Bursting Pressures
Pipe Dimension
(inches)
Bursting Pressure
(psi)
Working Pressure
(psi)
1/2 10380 1300
3/4 8610 1080
1 8090 1010
1 1/4 6745 840
1 1/2 6100 760
2 5185 650
2 1/2 5650 710
3 4940 620
3 1/2 5610 700
4 5270 660
5 4630 580
6 4220 530
7 3940 490
8 3720 470
9 3540 445
10 3380 420
12 2930 370
  • 1 psi (lb/in2) = 6,894.8 Pa (N/m2) = 6.895x10-3 N/mm2 = 6.895x10-2 bar = 27.71 in H2O at 62oF (16.7oC) = 703.1 mm H2O at 62oF (16.7oC) = 2.0416 in mercury at 62oF (16.7oC) = 51.8 mm mercury at 62oF (16.7oC) = 703.6 kg/m2 = 0.06895 atm = 2.307 Ft. H2O
Extra Strong Wrought Steel Pipes - XS - Schedule 80
Wrought Steel Pipes - Extra Strong - XS - Schedule 80 - Bursting Pressures
Pipe Dimension
(inches)
Bursting Pressure
(psi)
Working Pressure
(psi)
1/2 14000 1750
3/4 11730 1470
1 10890 1360
1 1/4 9200 1150
1 1/2 8420 1050
2 7340 920
2 1/2 7680 955
3 6860 860
3 1/2 7950 990
4 7480 940
5 6740 840
6 6510 810
7 6540 820
8 5770 720
9 5185 650
10 4645 580
12 3910 490
Double Extra Strong Wrought Steel Pipes - XXS
Wrought Steel Pipes - Double Extra Strong - XXS - Bursting Pressures
Pipe Dimension
(inches)
Bursting Pressure
(psi)
Working Pressure
(psi)
1/2 28000 3500
3/4 23460 2930
1 21780 2720
1 1/4 18400 2300
1 1/2 16840 2110
2 14680 1840
2 1/2 15355 1920
3 13710 1710
3 1/2 15900 1990
4 14965 1870
5 13475 1690
6 13035 1630
7 11465 1430
8 10140 1270
Pressure Ratings
Aluminum Tubing - Allowable Pressures
Allowable pressure for aluminum tubes.
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipes - Dimensions
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
Barlow's Formula - Calculate Internal, Allowable and Bursting Pressure
Calculate pipes internal, allowable and bursting pressure.
Carbon Steel Flanges - Pressure and Temperature Ratings
Maximum ratings for flanges conforming to ISO Standard 2229 dimensions and material specification AST-A-105.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Metric Units
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
Process Pipes - Allowable Stress vs. Temperature
Allowable wall stress in pipes according ASME M31.3.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Steel Tubes - Working Pressures vs. Size
Normal maximum working pressures for steel tubes - in psi and kPa.
Water Hammer
Rapidly closing or openingĀ valves - or starting stopping pumps - may cause pressure transients in pipelines known as surge or water hammers.
