Aluminum Tubing - Allowable Pressures
Allowable pressure in aluminum tubes based on ultimate tensile strength 42000 psig (290000 kPa):
Tube
O.D.
(inches)
Allowable Pressure (psig)
Wall Thickness (inches)
0.0350.0490.0650.083
1/8 8600
3/16 5600 8000
1/4 4000 5900
5/16 3100 4600
3/8 2600 3700
1/2 1900 2700 3700
5/8 1500 2100 2900
3/4 1700 2400 3100
7/8 1500 2000
1 1300 1700 2300
Pressure Ratings
ASME 31.3 Piping Materials - Allowable Pressure Calculator
Calculate ASME 31.3 allowable pressure
ASTM A53 B Carbon Steel Pipes - Allowable Pressure vs. Schedule and Size
Maximum working pressure of carbon steel pipe at temperature 400oF.
Barlow's Formula - Calculate Internal, Allowable and Bursting Pressure
Calculate pipes internal, allowable and bursting pressure.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Pipe Class Ratings vs. Pressure Numbers (PN)
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Wrought Steel Pipes - Bursting Pressures vs. Size
Theoretical bursting and working pressure of wrought steel standard, extra strong and double extra strong pipes.
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
