ASME 31.3 Piping Materials - Allowable Pressure Calculator
The ASME code B31.3 recommends allowable tensile stress levels in pipe materials. The equations used in B31.3 are
t = P D / (2 (S E + P Y)                    (1)
t = thickness of pipe (in)
P = internal pressure in pipe (psi)
D = outside diameter of pipe (in)
S = allowable tensile stress (psi)
E = quality factor for the piping according ASME 31.3
Y = wall thickness coefficient according ASME 31.3 (y = 0.5 for thin pipes and y < 0.5 for thick pipes)
or
t = P (d + 2 c) / (2 (S E - P (1 - Y))                    (2)
d = inside diameter of pipe (in)
c = sum of the mechanical allowances (thread or groove depth) plus corrosion and erosion allowances (in) - typical 0.02 in where tolerances are not specified
Eq. (1) can be rearranged to express allowable internal piping pressure as
p = 2 t S E / (D - 2 t Y)                      (1b)
Eq. (1b) can be modified to compensate for thinner pipes due to the thickness tolerances used by the industry.
p = 2 t (1 - α / 100) S E / (D - 2 t Y)                      (1c)
α = thickness tolerance (%)
For ASTM A53, A106 and other codes the accepted thickness tolerances are 12.5%.
Example - Allowable Pressure in a Steel Pipe
The allowable pressure in a 4 inch schedule 40 carbon steel pipe with outside diameter 4.5 in, wall thickness 0.237 in, thickness tolerance 12.5% and allowable stress 16000 psi - can with quality factor E for steel 0.8 and wall thickness coefficient 0.4 be calculated as
p = 2 (0.237 in) (1 - 12.5 / 100) (16000 psi) (0.8) / ((4.5 in) - 2 (0.237) 0.4)
   = 1232 psi
ASME 31.3 Allowable Pressure Calculator (from eq. 1b)
Quality Factors E
Some quality factors according ASME 31.3:
  • furnace butt weld joint, continuous weld joint, straight seam: 0.6
  • electrical resistance weld joint, straight or spiral seam: 0.85
  • double butt weld joint, straight or spiral seam, 100% radiographed: 1.0
Thickness Coefficients Y
The values of coefficient Y depends on type of material, temperature and thickness limits.
Thickness coefficients when t > D / 6:
Y = (d + 2 c) / (D + d + 2 c)                  (3)
Thickness coefficients when t < D / 6:
ASME 31.3 - Wall Thickness Coefficients Y
MaterialTemperature (oF)
< 900950100010501100> 1150
Ferritic steels 0.4 0.5 0.7 0.7 0.7 0.7
Autenitic steel 0.4 0.4 0.4 0.4 0.5 0.7
Other ductile materials 0.4 0.4 0.4 0.4 0.4
Cast iron 0.0
Pressure Ratings
Aluminum Tubing - Allowable Pressures
Allowable pressure for aluminum tubes.
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
ASTM A53 B Carbon Steel Pipes - Allowable Pressure vs. Schedule and Size
Maximum working pressure of carbon steel pipe at temperature 400oF.
Barlow's Formula - Calculate Internal, Allowable and Bursting Pressure
Calculate pipes internal, allowable and bursting pressure.
Capacitors - Parallel and Serial Connections
Parallel and serial connected capacitor circuits.
Carbon Steel Pipes - Pressure and Temperature Ratings, Imperial Units
Pressure (psig) and temperature (deg F) ratings for A-53 B and A-106 B, A333, A334 and API 5L carbon steel pipes - temperatures ranging 100 degF - 700 degF.
Carbon Steel Pipes - Pressure and Temperature Ratings, Metric Units
Pressure (kPa)> and temperature (degC) ratings of ASTM A-106, API 5L and ASTM A-53 Seamless Carbon Steel Pipes - temperatures ranging -29 degC - 450 degC.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Metals - Strength vs. Temperature
The influence of temperature on the strength of metals.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Steel Tubes - Working Pressures vs. Size
Normal maximum working pressures for steel tubes - in psi and kPa.
