Copper Tubes Type K, L and M - Working Pressures vs. Size
Working pressure of copper tubes type K, L and M are indicated in the table below.
Ratings based on service temperature max. 150 oF (66 oC).
- yield strength S = 5100 psi (35 MPa) for annealed
- yield strength S = 10000 psi (69 MPa) for drawn tube
Copper tube - Type K
| Nominal Size (in) | Working Pressure (psi) | Actual Burst Pressure (psi) | ||
| Annealed | Drawn | Annealed | Drawn | |
| 1/4 | 913 | 1796 | ||
| 3/8 | 960 | 1889 | ||
| 1/2 | 758 | 1490 | 4535 | 9840 |
| 5/8 | 626 | 1229 | ||
| 3/4 | 724 | 1424 | 4200 | 9300 |
| 1 | 557 | 1093 | 3415 | 7200 |
| 1 1/4 | 452 | 888 | 2800 | 5525 |
| 1 1/2 | 420 | 825 | 2600 | 5000 |
| 2 | 370 | 726 | 2235 | 3915 |
| 2 1/2 | 338 | 664 | 3575 | |
| 3 | 328 | 643 | 3450 | |
| 3 1/2 | 311 | 610 | ||
| 4 | 306 | 600 | 3415 | |
| 5 | 293 | 575 | 3585 | |
| 6 | 295 | 578 | 3425 | |
| 8 | 314 | 615 | 3635 | |
| 10 | 314 | 615 | ||
| 12 | 314 | 615 | ||
Copper tube - Type L
| 1/4 | 775 | 1524 | ||
| 3/8 | 662 | 1302 | ||
| 1/2 | 613 | 1206 | 3885 | 7765 |
| 5/8 | 537 | 1055 | ||
| 3/4 | 495 | 972 | 2935 | 5900 |
| 1 | 420 | 825 | 2650 | 5115 |
| 1 1/4 | 373 | 733 | 2400 | 4550 |
| 1 1/2 | 347 | 682 | 2200 | 4100 |
| 2 | 309 | 607 | 1910 | 3365 |
| 2 1/2 | 285 | 560 | 3215 | |
| 3 | 270 | 529 | 2865 | |
| 3 1/2 | 258 | 506 | ||
| 4 | 249 | 489 | 2865 | |
| 5 | 229 | 449 | 2985 | |
| 6 | 213 | 418 | 2690 | |
| 8 | 230 | 451 | 2650 | |
| 10 | 231 | 452 | ||
| 12 | 215 | 423 | ||
Copper tube - Type M
| 3/8 | 485 | 953 | ||
| 1/2 | 420 | 825 | 6135 | |
| 3/4 | 346 | 680 | 4715 | |
| 1 | 286 | 563 | 3865 | |
| 1 1/4 | 287 | 565 | 3875 | |
| 1 1/2 | 282 | 553 | 3550 | |
| 2 | 254 | 499 | 2935 | |
| 2 1/2 | 233 | 457 | 2800 | |
| 3 | 215 | 423 | 2665 | |
| 3 1/2 | 214 | 421 | ||
| 4 | 213 | 419 | 2215 | |
| 5 | 198 | 388 | 2490 | |
| 6 | 186 | 364 | 2000 | |
| 8 | 195 | 382 | 2285 | |
| 10 | 195 | 383 | ||
| 12 | 195 | 383 | ||
- 1 N/mm2 = 106 Pa (N/m2) = 1 MPa = 10 bar = 1.020×105 kp/m2 = 102.0 m H2O = 9.869 atm = 145.0 psi (lbf/in2)
- 1 in = 25.4 mm
• Pressure Ratings of Pipes and Fittings
• Water Systems
Aluminum Tubing - Allowable Pressures
Allowable pressure for aluminum tubes.
ASME 31.3 Piping Materials - Allowable Pressure Calculator
Calculate ASME 31.3 allowable pressure
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
ASTM B88 - Seamless Copper Water Tubes - Dimensions
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
Barlow's Formula - Calculate Internal, Allowable and Bursting Pressure
Calculate pipes internal, allowable and bursting pressure.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Density, specific heat and thermal conductivity of copper vs. temperature
Copper Tubes - Equivalent Length Pressure Loss in Fittings and Valves
Copper tube fittings and equivalent lengths - in feets of straight tube.
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Copper Tubes - Heat Carrying Capacities
Hot water heat carrying capacities in copper tubes type L.
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
EN 12449 - Copper and Copper Alloys - Seamless, Round Tubes for General Purposes - Dimensions
Dimensions of copper tubes according EN 12449.
Pipe vs. Tube
Pipes and tubes are not exactly the same
Solder Joints - Pressure Ratings vs. Temperature
Solder joints and their pressure ratings according ASME B16.18.
Steel Tubes - Working Pressures vs. Size
Normal maximum working pressures for steel tubes - in psi and kPa.
