- d -
(mm)
• Recommended
where R220 is material temper.
Material Temper | Size Range | Tensile Strength | Elongation min. | Vickers Hardness | |
EN 1173 Designation | Commonly used term | (mm) | (MPa) | (%) | HV5 |
R220 | annealed, soft | 6 - 54 | 220 | 40 | 40 - 70 |
R250 | half hard | 6 - 66.7 | 250 | 20 | 75 - 100 |
R290 | hard | 6 - 159 | 290 | 5 | 95 - 120 |
Nominal Outside Diameter (mm) | Tube Length (m) | Wall Thickness (mm) | |
X1) | Y1) | ||
6 | 3, 6 | 0.6 | 0.8 |
8 | 3, 6 | 0.6 | 0.8 |
10 | 3, 6 | 0.6 | 0.8 |
15 | 3, 6 | 0.7 | 1.0 |
22 | 3, 6 | 0.9 | 1.2 |
28 | 3, 6 | 0.9 | 1.2 |
35 | 3, 6 | 1.2 | 1.5 |
42 | 3, 6 | 1.2 | 1.5 |
54 | 3, 6 | 1.2 | 2.0 |
67 | 3, 6 | 1.2 | 2.0 |
76 | 3, 6 | 1.5 | 2.0 |
108 | 3, 6 | 1.5 | 2.5 |
133 | 3, 6 | 1.5 | |
159 | 3, 6 | 2.0 | |
219 | 6 | 3.0 |
1) BS 2871 - Copper Tubes - Dimensions and Working Pressures Table X, Y and Z
Nominal Outside Diameter (mm) | Coil Length (m) | Wall Thickness (mm) |
15 | 25 | 1.0 |
22 | 25 | 1.2 |
15 | 2, 3 | 0.7 |
22 | 2, 3 | 0.9 |
28 | 3 | 0.9 |
35 | 3 | 1.0 |
42 | 3 | 1.0 |
54 | 3 | 1.0 |
8 | 25 | 0.6 |
10 | 25 | 0.7 |
15 | 25 | 1.0 |
22 | 25 | 1.2 |
28 | 20 | 1.2 |
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
Density, specific heat and thermal conductivity of copper vs. temperature
Bending copper pipe and tube temperatures.
Copper tubes corrosion resistance to different products and chemicals.
Copper tube fittings and equivalent lengths - in feets of straight tube.
Hot water heat carrying capacities in copper tubes type L.
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Maximum space between supports aand clips for copper tubes.
Copper tube sizes used in plumbing.
Dimensions of copper tubes according EN 12449.
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
