Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
Standard sizes specification for seamless red brass pipes.
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
British standards and specifications for pipe, tube and fittings.
Density, specific heat and thermal conductivity of copper vs. temperature
Bending copper pipe and tube temperatures.
Copper tubes corrosion resistance to different products and chemicals.
Copper tube fittings and equivalent lengths - in feets of straight tube.
Capacity of copper tubes expansion loops.
Hot water heat carrying capacities in copper tubes type L.
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Maximum space between supports aand clips for copper tubes.
Physical characteristics of copper tubes ASTM B 88 type K.
Copper tube sizes used in plumbing.
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
Dimensions of copper tubes according EN 12449.
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Heat loss to surrounding air from insulated copper tubes.
Temperature ranges for bending nickel and nickel alloy pipes and tubes.
SI vs. Imperial pipe sizes.
Water content in steel pipes and copper tubes.
Solder joints and their pressure ratings according ASME B16.18.
