Nickel and Nickel Alloy Pipes - Temperature Ranges
Temperature ranges for hot bending nickel and nickel alloy pipes and tubes:
Copper or Copper Alloy | Temperature Range (oF) |
Nickel | 1200 - 2300 |
Nickel Copper | 1700 - 2150 |
Ni-Cr-Fe | 1850 - 2300 |
Ni-Fe-Cr | 1850 - 2200 |
Low Carbon Nickel | 1200 - 2300 |
- T (oC) = 5/9 (T (oF) - 32)
ASTM B88 - Seamless Copper Water Tubes - Dimensions
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper and Copper Alloy Pipes - Temperature Ranges
Bending copper pipe and tube temperatures.
Copper Tubes - Equivalent Length Pressure Loss in Fittings and Valves
Copper tube fittings and equivalent lengths - in feets of straight tube.
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
Piping Elbows - Thrust Block Forces
Thrust block forces on pipe bends anchors due to liquid velocities and internal pressures - online resulting force calculator.
