(oF)
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
Copper tube fittings and equivalent lengths - in feets of straight tube.
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
Dimensions of copper tubes according EN 12449.
Temperature ranges for bending nickel and nickel alloy pipes and tubes.
Thrust block forces on pipe bends anchors due to liquid velocities and internal pressures - online resulting force calculator.
