ASTM B302 - Threadless Copper Pipes - Dimensions
Seamless copper pipe according ASTM B302 Standard Specification for Threadless Copper Pipe, Standard Sizes:
Nominal Pipe Size (in) | Outside Diameter (in) | Wall Thichness (in)) | Weight (lb/ft) |
1/4 | 0.540 | 0.065 | 0.376 |
3/8 | 0.675 | 0.065 | 0.483 |
1/2 | 0.840 | 0.065 | 0.613 |
3/4 | 1.050 | 0.065 | 0.780 |
1 | 1.315 | 0.065 | 0.989 |
1 1/4 | 1.660 | 0.065 | 1.26 |
1 1/2 | 1.900 | 0.065 | 1.45 |
2 | 2.375 | 0.065 | 1.83 |
2 1/2 | 2.875 | 0.065 | 2.22 |
3 | 3.500 | 0.083 | 3.45 |
3 1/2 | 4.000 | 0.095 | 4.52 |
4 | 4.500 | 0.107 | 5.72 |
5 | 5.562 | 0.132 | 8.73 |
6 | 6.625 | 0.158 | 12.4 |
8 | 8.625 | 0.205 | 21.0 |
10 | 10.750 | 0.256 | 32.7 |
12 | 12.750 | 0.313 | 47.4 |
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
ASTM B88 - Seamless Copper Water Tubes - Dimensions
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper and Copper Alloy Pipes - Temperature Ranges
Bending copper pipe and tube temperatures.
Copper Tubes - Equivalent Length Pressure Loss in Fittings and Valves
Copper tube fittings and equivalent lengths - in feets of straight tube.
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Copper Tubes - Heat Carrying Capacities
Hot water heat carrying capacities in copper tubes type L.
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
LPG Pipes - Pressure Loss vs. Gas Flow
Resistance and pressure loss in liquid LPG pipes.
