Temper describes the strength and hardness of the tube.
Nominal Size (inches) | Max. Working Pressure (psi) | ||
Annealed Coils | Annealed Straight Lengths | Drawn Straight Lengths | |
1/8 | 2613 | ||
3/16 | 1645 | ||
1/4 | 1195 | ||
5/19 | 1017 | ||
3/8 | 836 | 777 | 1524 |
1/2 | 618 | 664 | 1302 |
5/8 | 525 | 615 | 1206 |
3/4 | 435 | 538 | 1055 |
7/8 | 495 | 496 | 972 |
1 1/8 | 420 | 421 | 825 |
1 3/8 | 373 | 374 | 733 |
1 5/8 | 347 | 348 | 682 |
2 1/8 | 309 | 607 | |
2 5/8 | 286 | 560 | |
3 1/8 | 270 | 529 | |
3 5/8 | 258 | 506 | |
4 1/8 | 249 | 489 |
Ratings based on service temperature max. 150oF (66oC).
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
Copper tubes corrosion resistance to different products and chemicals.
Copper tube fittings and equivalent lengths - in feets of straight tube.
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Maximum space between supports aand clips for copper tubes.
Physical characteristics of copper tubes ASTM B 88 type K.
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
Dimensions of copper tubes according EN 12449.
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Pipes and tubes are not exactly the same
Solder joints and their pressure ratings according ASME B16.18.
