- d -
(mm)
• Recommended
where R290 is material temper .
Material Temper | Tensile Strength | Elongation min. | Vickers Hardness | |
Designation | Commonly used term | (MPa) | (%) | HV5 |
R250 | half hard | 250 | 30, 20 | 75 - 100 |
R290 | hard | 290 | 3 | over 100 |
Nominal Outside Diameter (mm) | Tube Length (m) | Wall Thickness (mm) |
12 | 6 | 0.6 |
15 | 3, 6 | 0.7 |
22 | 3, 6 | 0.9 |
28 | 3, 6 | 0.9 |
35 | 6 | 1.0 |
42 | 6 | 1.0 |
54 | 6 | 1.0 |
67 | 6 | 1.5 |
76 | 6 | 1.5 |
108 | 6 | 1.5 |
133 | 6 | 1.5 |
159 | 6 | 2.0 |
219 | 6 | 3.0 |
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
Dimensions of copper tubes used in medical gas systems.
Maximum space between supports aand clips for copper tubes.
Physical characteristics of copper tubes ASTM B 88 type K.
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Solder joints and their pressure ratings according ASME B16.18.
