Copper Tubes Supports
Copper Tubes - Maximum space between Supports
SizeHorizontal RunVertical Run
(mm)(in)(m)(ft)(m)(ft)
6 0.4 1.3 0.6 2
8 0.6 2 0.9 3
10 3/8 0.8 2.6 1.2 4
12 1.0 3.3 1.5 5
15 1/2 1.2 4 1.8 6
22 3/4 1.2 4 1.8 6
28 1 1.5 5 2.4 8
35 1 1/4 1.8 6 3.0 10
42 1 1/2 1.8 6 3.0 10
54 2 1.8 6 3.0 10
67 2 1/2 2.4 8 3.7 12
76 3 2.4 8 3.7 12
108 4 2.4 8 3.7 12
133 5 3.0 10 3.7 12
159 6 3.7 12 3.7 12
Example - Support of Copper Tube
The maximum distance between the horizontal supports of a 1" (28 mm) copper tube is 5 ft (1.5 m).
Dimensions
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B43 - Seamless Red Brass Pipes - Dimensions
Standard sizes specification for seamless red brass pipes.
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
ASTM B88 - Seamless Copper Water Tubes - Dimensions
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
EN 12449 - Copper and Copper Alloys - Seamless, Round Tubes for General Purposes - Dimensions
Dimensions of copper tubes according EN 12449.
EN 12735 Seamless, Round Copper Tubes for Air Conditioning and Refrigeration - Dimensions
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
EN 13348 Seamless, Round Copper Tubes for Medical Gases or Vacuum - Dimensions
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
Pressfit Pipes - Supports
Maximum distance between pressfit pipe supports.
PVDF - PolyVinylidene Fluoride Pipes - Supports
Maximum distance between PVDF pipe supports.
Solder Joints - Pressure Ratings vs. Temperature
Solder joints and their pressure ratings according ASME B16.18.
Steel Pipes - Supports
Recommended max. distance between steel pipe supports.
Thermoplastic Pipes - Supporting Distances vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
