Steel Pipes - Supports
Support Spacing in Meter
Outside Diameter (mm) | Steel Pipe - Distance between Supports (m) | |
Horizontal Run | Vertical Run | |
15 | 1.5 | 3.0 |
20 | 2.4 | 3.0 |
25 | 2.4 | 3.0 |
32 | 2.4 | 3.7 |
40 | 2.4 | 3.7 |
50 | 2.4 | 4.6 |
65 | 3.0 | 4.6 |
80 | 3.0 | 4.6 |
100 | 3.0 | 5.5 |
Support Spacing in Feet
Nominal Pipe Size (in) | Support Spacing (ft) |
1 | 7 |
1 1/2 | 9 |
2 | 10 |
3 | 12 |
4 | 14 |
6 | 17 |
8 | 19 |
10 | 22 |
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
Pressfit Pipes - Supports
Maximum distance between pressfit pipe supports.
PVDF - PolyVinylidene Fluoride Pipes - Supports
Maximum distance between PVDF pipe supports.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
