Thermoplastic Pipes - Support Distance vs. Temperature
Temperatures and maximum distance between supports for pipes made of
  • PVDF - PolyVinylidene Fluoride
  • CPVC - Chlorinated Polyvinyl Chloride
  • PVC - Polyvinyl Chloride
  • PP - PolyPropylene
are indicated in the diagrams below.
PVC Pipes
  • 1 ft (foot) = 0.3048 m
  • T(oF) = (T(oC))(9/5) + 32
CPVC Pipes
PVDF Pipes
PP Pipes
Piping Systems
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
ASTM F2389 Pressure-rated Polypropylene (PP) - Dimensions
Dimensions of pressure rated PP pipes according ASTM F2389.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports.
CPVC Pipes - Operating and Collapsing Pressures vs. Schedule and Size
Maximum operating and bursting pressures of CPVC - Chlorinated Poly (Vinyl Chloride) - piping systems.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
Epoxy Pipes - Support Spacing
Support spacing for reinforced Epoxy fiberglass pipes.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Plastic Pipes - Friction Head Loss vs. Water Flow
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
PVDF - PolyVinylidene Fluoride Pipes - Supports
Maximum distance between PVDF pipe supports.
Recommended max. distance between steel pipe supports.
