EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
EN 1451 Polypropylene (PP) plastics piping dimensions:
Metric Based Series
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions Metric Series
Nominal Outside Diameter
(mm)
Wall Thickness
(mm)
32 3.0
40 3.0
50 3.0
63 3.0
75 3.0
90 3.4
110 3.4
125 3.9
160 4.9
200 6.2
250 7.7
315 9.7
Inch-based Series
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions Imperisal Series
Nominal Size
(DN)
Equivalent Inch Dimension
(inch)
(mm)
Mean Outside Diameter
(mm)
34 1 1/4 34 34.6
41 1 1/2 41 41.0
54 2 54 54.1
Dimensions of Pipes and Tubes
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
ASTM F2389 Pressure-rated Polypropylene (PP) - Dimensions
Dimensions of pressure rated PP pipes according ASTM F2389.
BS 7291 - Thermoplastics Pipes for Hot and Cold Water - Dimensions
Dimensions of thermoplastic pipes - PEX and PB according BS 7291.
Chemical Resistance of Thermoplastics
Chemical resistance of thermoplastics like ABS, CPVC, PP, PVC, PE, PB, PVDF and PEX piping materials to chemicals and products ranging beer, acryl acid, diesel oil and many more.
Dimensions of PVC pipes according EN 1401.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
Underground Pipes - Earth Pressure
Pressure acting on underground pipes due to weight of soil and transport.
