(68 oF)
Product | Rating 1) | |
20 oC (68 oF) | 60 oC (140 oF) | |
Aqua ammonia | 1 | 1 |
Calciumhydroxide | 1 | 1 |
Potassiumhydroxide | 1 | 1 |
Caustic soda | 1 | 1 |
Acid salt 2) | 1 | 1 |
Basic salt 3) | 1 | 1 |
Neutral salt 4) | 1 | 1 |
Various salt | ||
Potassium bicarbonate | 1 | 2 |
Potassium permanganate | 1 | 2 |
Sodium cyanide | 1 | 1 |
Natriumferricyanid | 1 | 2 |
Sodium hypochlorite | 2 | 3 |
Acetone | 2 | 2 |
Aniline | 1 | 1 |
Benzol | 3 | 4 |
Petrol | 4 | 4 |
Butyl alcohol | 1 | 1 |
Ethyl acetate | 2 | 4 |
Ethyl alcohol | 1 | 1 |
Ethyl dichloride | 3 | 4 |
Ethyl ether | 4 | 4 |
Phenol | 2 | 2 |
Formalin 37% | 1 | 2 |
Heptanes | 3 | 4 |
Chlorobenzene | 3 | 4 |
Chloroform | 4 | 4 |
Carbon disulphide | 4 | 4 |
Carbon tetrachloride | 4 | 4 |
Methyl alcohol | 1 | 1 |
Methylene (di)chloride | 4 | 4 |
Methyl ethyle ketone | 3 | 4 |
Nitrobenzene | 3 | 4 |
Toluene | 3 | 4 |
Trichlorethylene | 4 | 4 |
Gases | ||
Chlorine (damp) | 2 | 4 |
Chlorine (dry) | 2 | 4 |
Carbon dioxide | 1 | 1 |
Carbon monoxide | 1 | 1 |
Sulphur dioxide (damp) | 2 | 3 |
Sulphur dioxide (dry) | 2 | 3 |
Hydrogen sulphide | 1 | 1 |
1) Rating:
2) Acid salt (normally aqueous) aluminum chloride, aluminum phosphate, copper chloride, sulphate of copper, ferrous sulphate, ferric chloride, stannic chloride, chloride of zinc, white vitriol etc
3) Basic salt (normally aqueous) bicarbonate of potassium, potash, sodium bicarbonate, sodium carbonate, sodium phosphate etc.
4) Neutral salt (normally aqueous) calcium chloride, calcium nitrate, calcium sulphate, magnesium chloride, nitrate of potassium, potassium sulphate, sodium chloride, sodium nitrate, sodium sulphate etc.
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Dimensions of pressure rated PP pipes according ASTM F2389.
Chemical resistance of thermoplastics like ABS, CPVC, PP, PVC, PE, PB, PVDF and PEX piping materials to chemicals and products ranging beer, acryl acid, diesel oil and many more.
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
Chemical resistance of Epoxy to common products like Acetic acid, Alcohol, Diesel oil and more.
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Chemical resistance of Polyurethane (PUR).
Maximum distance between PolyPropylene pipes supports.
Chemical resistance of Polyvinyl Chloride PVC.
Rsistance to chemicals - solvents and softeners - swelling properties.
Chemical resistance of silicone.
Chemical resistance of Vinyl Ester to products as Acetone, Alcohol, Diesel oil and more.
