PVC Polyvinyl Chloride - Chemical Resistance
Chemical resistance of PVC - Polyvinyl Chloride - to common products is indicated in the table below.
- R = resistant up to 60oC (140oF)
- R23 = resistant up to 23oC (73oF)
- N = not resistant
Chemical Product | Resistance |
Acetic Acid 0-25% (vinegar) | R |
Acetic Acid 25-50% | R23 |
Alcohol - Butyl | R |
Alcohol - Isopropyl | R |
Alum (Aluminum Sulfate) | R |
Aluminum Chloride, Aqueous | R |
Aluminum Potassium Sulfate | R |
Ammonium Bisulfide | R |
Ammonium Hydroxide 10% | R |
Ammonium Nitrate | R |
Ammonium Persulfate | R |
Ammonium Phosphate | R |
Ammonium Sulfate | R |
Barium Carbonate | R |
Barium Chloride | R |
Barium Sulfate | R |
Barium Sulfide | R |
Beer | R |
Benzene | N |
Benzoic Acid | R |
Benzyl Alcohol | N |
Butyric Acid 0-50% | R23 |
Cadmium Cyanide | R |
Calcium Bisulfide | N |
Calcium Carbonate | R |
Calcium Chlorate | R |
Calcium Chloride | R |
Calcium Hydroxide | R |
Calcium Hypochlorite | R |
Calcium Nitrate | R |
Calcium Sulfate | R |
Carbon Dioxide | R |
Carbon Monoxide | R |
Carbonic Acid | R |
Chlorine - 0-20 ppm | R23 |
Chlorine, liquid | N |
Chlorinated Water | R |
Chloroacetic Acid 0-50% | R |
Citric Acid | R |
Coconut Oil | R |
Coffee | R |
Coke Oven Gas | R |
Copper Chloride | R |
Copper Cyanide | R |
Copper Fluoride | R |
Copper Nitrate | R |
Copper Sulfate | R |
Corn Oil | R |
Corn Syrup | R |
Cottonseed Oil | R |
Crude Oil | R |
Cyclohexane | N |
Diesel Fuel | R |
Dioctyl Phthalate | N |
Dipropylene Glycol | R |
Ethylene Glycol | R |
Fatty Acids | R |
Ferric Chloride | R |
Ferric Nitrate | R |
Ferric Sulfate | R |
Ferrous Chloride | R |
Ferrous Nitrate | R |
Ferrous Sulfate | R |
Fish Oil | R |
Fluoboric Acid | R |
Fluorsilicic Acid 30% | R |
Formaldehyde | R |
Formic Acid | R23 |
Fuel JP-4,5 | R |
Gas, Natural | R |
Gasoline | R |
Gasohol | R |
Gasoline, Sour | R |
Glycol, Acid | R |
Glucose | R |
Glycerin | R |
Glycol | R |
Glycolic Acid | R |
Heptane | R |
n-Hexane | R23 |
Hydraulic oil (petroleum) | R23 |
Hydrobromic Acid 20% | R |
Hydrocyanic Acid | R |
Hydrofluoric Acid | R23 |
Hydrogen | R |
Hydrogen Cyanide | R |
Hydrogen Fluoride | N |
Hydrogen Peroxide 50% | R |
Hydrogen Sulfide Dry, Wet | R |
Hypochlorous Acid | R |
Iodine I2 | N |
Kerosene | R |
Lactic Acid 25% | R |
Lead Acetate | R |
Magnesium Carbonate | R |
Magnesium Chloride | R |
Magnesium Nitrate | R |
Magnesium Sulfate | R |
Malic Acid | R |
Mercuric Chloride | R |
Mercurous Nitrate | R |
Methane | R |
Methanol | R |
Milk | R |
Mineral Oil | R |
Motor Oil | R |
Naphtha | R |
Naphthalene | R |
Nickel Chloride | R |
Nickel Nitrate | R |
Nickel Sulfate | R |
Nicotine | R |
Nitric Acid | R |
Nitro Benzene | N |
Nitro Glycerine | N |
Oleic Acid | R |
Olive Oil | R |
Oxalic Acid 50% | R |
Phosphoric Acid | R |
Picric Acid, Alcoholic | N |
Potassium Aluminum Sulfate | R |
Potassium Bicarbonate | R |
Potassium Carbonate | R |
Potassium Chloride | R |
Potassium Ferrocyanide | R |
Potassium Nitrate | R |
Potassium Permanganate 10% | R |
Potassium Persulfate | R |
Pyridine | N |
Silver Nitrate | R |
Soaps | R |
Sodium Acetate | R |
Sodium Benzoate | R |
Sodium Bisulfate | R |
Sodium Bisulfite | R |
Sodium Bromide | R |
Sodium Carbonate | R |
Sodium Chlorate | R |
Sodium Chloride | R |
Sodium Chlorite | N |
Sodium Cyanide | R |
Sodium Dichromate | R |
Sodium Phosphate | R |
Sodium Ferricyanide | R |
Sodium Hydroxide | R |
Sodium Hypochlorite | R23 |
Sodium Meta-Phosphate | R |
Sodium Nitrate | R |
Sodium Silicate | R |
Sodium Sulfate | R |
Sodium Sulfide | R |
Sodium Sulfite | R |
Sodium Thiosulfate | R |
Stannic Chloride | R |
Stannous Chloride | R |
Stearic Acid | R |
Sugar, Sucrose | R |
Sulfamic Acid | N |
Sulfuric Acid 0-80% | R |
Sulfuric Acid 90% | R23 |
Sulfuric Acid > 93% | N |
Sulfurous Acid | R |
Tall Oil | R |
Tannic Acid | R |
Tartaric Acid | R |
Toluene (Toluol) | N |
Transformer Oil | R |
Trichloroacetic Acid 50% | R |
Trisodium Phosphate | R |
Urea | R |
Vegetable Oils | R |
Vinegar | R |
Water - Deionized | R |
Water - Demineralized | R |
Water - Distilled | R |
Water - Fresh | R |
Water - Salt | R |
Water - Sea | R |
White Liquor - Pulp Mill | R |
Wine | R |
Xylene (Xylol) | N |
Zinc Chloride | R |
Zinc Nitrate | R |
Zinc Sulfate | R |
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
Epoxy - Chemical Resistance
Chemical resistance of Epoxy to common products like Acetic acid, Alcohol, Diesel oil and more.
Polyurethane - Chemical Resistance
Chemical resistance of Polyurethane (PUR).
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
Rubbers and Elastomers - Chemical Resistance
Rsistance to chemicals - solvents and softeners - swelling properties.
Silicone - Chemical Resistance
Chemical resistance of silicone.
Vinyl Ester - Chemical Resistance
Chemical resistance of Vinyl Ester to products as Acetone, Alcohol, Diesel oil and more.
