Epoxy - Chemical Resistance
Epoxy (polyepoxide) is an epoxide polymer that cures when mixed with a catalyzing agent or "hardener". Epoxy resin have an excellent electrical, thermal, and chemical resistance. It is common to increase the strength of epoxy with fibrous reinforcement or mineral fillers. The variety of combinations of epoxy resins and reinforcements provides a wide latitude in properties obtainable in molded parts.
The table below can be used as an indication of epoxy resistance to chemical compounds. Always check the chemical resistance with the epoxy manufacturer.
Product | Epoxy Resistance |
Acetic Acid (20%) | Excellent |
Acetone | Not Recommended |
Acetylene | Excellent |
Alcohol - Ethyl | Excellent (temperature < 120 oF, 50 oC) |
Alcohol - Isopropyl | Excellent |
Alcohol - Methyl | Good (temperature < 71 oF, 22 oC) |
Aluminum Chloride | Excellent (temperature < 71 oF, 22 oC) |
Aluminum Fluoride | Good (temperature < 71 oF, 22 oC) |
Aluminum Hydroxide | Good (temperature < 71 oF, 22 oC) |
Aluminum Sulfate | Excellent (temperature < 71 oF, 22 oC) |
Amines | Excellent (temperature < 71 oF, 22 oC) |
Ammonia - Liquid | Excellent (temperature < 71 oF, 22 oC) |
Ammonia 10% | Excellent (temperature < 71 oF, 22 oC) |
Ammonium Carbonate | Excellent (temperature < 71 oF, 22 oC) |
Ammonium Chloride | Excellent (temperature < 71 oF, 22 oC) |
Ammonium Hydroxide | Excellent (temperature < 71 oF, 22 oC) |
Ammonium Nitrate | Excellent (temperature < 71 oF, 22 oC) |
Ammonium Phosphate | Excellent (temperature < 71 oF, 22 oC) |
Ammonium Sulfate | Excellent (temperature < 71 oF, 22 oC) |
Amyl acetate | Excellent (temperature < 71 oF, 22 oC) |
Aniline | Fair (temperature < 71 oF, 22 oC) |
Barium Carbonate | Excellent (temperature < 71 oF, 22 oC) |
Barium Chloride | Excellent (temperature < 71 oF, 22 oC) |
Barium Hydroxide | Excellent (temperature < 71 oF, 22 oC) |
Barium Sulfate | Fair (temperature < 71 oF, 22 oC) |
Barium Sulfide | Good (temperature < 71 oF, 22 oC) |
Beer | Excellent (temperature < 71 oF, 22 oC) |
Benzol | Excellent (temperature < 71 oF, 22 oC) |
Borax | Excellent (temperature < 71 oF, 22 oC) |
Boric acid | Excellent (temperature < 71 oF, 22 oC) |
Bromine | Not Recommended |
Butadiene gas | Excellent (temperature < 71 oF, 22 oC) |
Butane gas | Excellent (temperature < 71 oF, 22 oC) |
Butyl acetate | Good (temperature < 71 oF, 22 oC) |
Butaric Acid | Fair (temperature < 71 oF, 22 oC) |
Calcium Bisulfite | Excellent (temperature < 71 oF, 22 oC) |
Calcium Carbonate | Excellent (temperature < 71 oF, 22 oC) |
Calcium Chloride | Excellent (temperature < 71 oF, 22 oC) |
Calcium Hydroxide | Excellent (temperature < 71 oF, 22 oC) |
Calcium Hypochlorite | Excellent (temperature < 71 oF, 22 oC) |
Calcium Sulfate | Excellent (temperature < 71 oF, 22 oC) |
Carbon dioxide gas | Excellent (temperature < 71 oF, 22 oC) |
Carbon Tetrachloride | Excellent (temperature < 71 oF, 22 oC) |
Carbonic Acid | Good (temperature < 71 oF, 22 oC) |
Citric Acid | Excellent (temperature < 71 oF, 22 oC) |
Copper Chloride | Excellent |
Copper Nitrate | Excellent (temperature < 71 oF, 22 oC) |
Dichloroethane | Good (temperature < 120 oF, 50 oC) |
Diesel Fuel | Excellent (temperature < 71 oF, 22 oC) |
Ethyl acetate | Fair (temperature < 71 oF, 22 oC) |
Ethyl chloride | Excellent (temperature < 71 oF, 22 oC) |
Ethylene glycol | Fair (temperature < 71 oF, 22 oC) |
Fatty Acids | Excellent (temperature < 71 oF, 22 oC) |
Ferric Chloride | Excellent (temperature < 71 oF, 22 oC) |
Ferric Sulfate | Excellent (temperature < 71 oF, 22 oC) |
Ferrous Chloride | Excellent (temperature < 71 oF, 22 oC) |
Ferrous Sulfate | Excellent (temperature < 71 oF, 22 oC) |
Fluorine gas | Note Recommended |
Fluosilicic acid | Fair |
Formaldehyde, 40% | Excellent (temperature < 71 oF, 22 oC) |
Formic Acid | Fair (temperature < 71 oF, 22 oC) |
R-12 dichlorodifluoromethane | Excellent |
Gasoline | Excellent |
Glucose | Good |
Glycerine | Excellent |
Heptane | Excellent |
Hexane | Good |
Hydraulic Fluid | Excellent |
Hydrobromic Acid, 100% | Not Recommended |
Hydrochloric acid, 20% | Good (temperature < 71 oF, 22 oC) |
Hydrocyanic Acid | Excellent |
Hydrofluoric Acid, 75% | Good (temperature < 71 oF, 22 oC) |
Hydrogen Peroxide, 10% | Fair (temperature < 71 oF, 22 oC) |
Hydrogen Sulfide | Excellent |
Jet Fuel | Excellent |
Kerosene | Excellent |
Lactic Acid | Good (temperature < 71 oF, 22 oC) |
Lead acetate | Excellent |
Magnesium Carbonate | Excellent |
Magnesium Chloride | Excellent |
Magnesium Hydroxide | Excellent |
Magnesium Nitrate | Excellent |
Magnesium Sulfate | Excellent |
Maleic Acid | Excellent |
Mercury | Excellent |
Methyl Ethyl Ketone | Fair (temperature < 71 oF, 22 oC) |
Naphtha | Excellent |
Naphthalene | Excellent |
Nickel Chloride | Excellent |
Nickel Sulfate | Excellent |
Nitric Acid | Not Recommended |
Oil - Castor | Excellent |
Oleic acid | Excellent |
Oxalic Acid | Excellent |
Phenol | Good |
Phosphoric Acid | Good |
Picric Acid | Excellent |
Potassium Bicarbonate | Excellent |
Potassium Bromide | Excellent |
Potassium Carbonate | Excellent |
Potassium Chloride | Excellent |
Potassium Dichromate | Fair |
Potassium Hydroxide | Excellent |
Potassium Nitrate | Excellent |
Potassium Sulfate | Excellent |
Propane, liquid | Excellent |
Silver Nitrate | Excellent |
Soaps | Excellent |
Sodium Acetate | Excellent |
Sodium Bicarbonate | Excellent |
Sodium Bisulfate | Excellent |
Sodium Carbonate | Fair (temperature < 71 oF, 22 oC) |
Sodium Chlorate | Excellent |
Sodium Chloride | Excellent |
Sodium Cyanide | Excellent |
Sodium Fluoride | Excellent |
Sodium Hydroxide, 50% | Good (temperature < 120 oF, 50 oC) |
Sodium Hypochlorite, 100% | Not Recommended |
Sodium Nitrate | Excellent |
Sodium Silicate | Excellent |
Sodium Sulfate | Excellent |
Sodium Sulfite | Excellent |
Sodium Thiosulfate | Excellent |
Stannic Chloride | Excellent |
Stearic Acid | Good |
Sulfuric Acid, 75-100% | Fair (temperature < 71 oF, 22 oC) |
Sulfur Dioxide | Excellent (temperature < 71 oF, 22 oC) |
Tannic Acid | Excellent |
Tartaric Acid | Excellent |
Toluene | Good (temperature < 71 oF, 22 oC) |
Turpentine | Good |
Urine | Excellent |
Vinegar | Excellent |
Water - Distilled | Excellent |
Water - Fresh | Excellent |
Water - Sea, Salt | Excellent |
Xylene | Excellent |
Zinc Chloride | Excellent |
• Corrosion
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Epoxy Pipes - Support Spacing
Support spacing for reinforced Epoxy fiberglass pipes.
Fiberglass Pipes and Temperature Limits
Temperature ranges for fiberglass Epoxy, Furan, Phenolic, Polyester and Vinyl Ester pipes.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Polyurethane - Chemical Resistance
Chemical resistance of Polyurethane (PUR).
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
PVC Polyvinyl Chloride - Chemical Resistance
Chemical resistance of Polyvinyl Chloride PVC.
Vinyl Ester - Chemical Resistance
Chemical resistance of Vinyl Ester to products as Acetone, Alcohol, Diesel oil and more.
