Epoxy Pipes - Support Spacing
Maximum distance between epoxy fiberglass pipe supports at different operating temperatures are indicated in the table below. Maximum operating temperature for epoxy pipes should not exceed 300 oF (149 oC).
Nominal Pipe SizeTemperature
oCoFoCoFoCoFoCoFoCoFoCoF
2475661507917593200107225121250
Maximum Support Spacing
inchesmmmftmftmftmftmftmft
1 25 3.2 9.9 3.0 9.8 3.0 9.7 2.9 9.4 2.8 9.3 2.7 8.7
1 1/2 40 3.5 11.6 3.5 11.4 3.4 11.3 3.4 11.0 3.3 10.8 3.1 10.1
2 50 4.0 13.1 3.9 12.9 3.9 12.8 3.8 12.4 3.7 12.2 3.5 11.4
3 80 4.6 15.0 4.5 14.8 4.5 14.6 4.3 14.2 4.3 14.0 4.0 13.0
4 100 5.1 16.7 5.0 16.5 5.0 16.3 4.8 15.8 4.8 15.6 4.4 14.5
6 150 5.8 18.9 5.7 18.6 5.6 18.4 5.5 17.9 5.4 17.6 5 16.4
8 200 6.1 20.0 6.1 20.0 6.0 19.8 5.9 19.3 5.8 19.0 5.4 17.7
10 250 6.1 20.0 6.1 20.0 6.1 20.0 6.1 20.0 6.1 20.0 5.7 18.8
12 300 6.1 20.0 6.1 20.0 6.1 20.0 6.1 20.0 6.1 20.0 6.0 19.7
14 350 6.1 20.0 6.1 20.0 6.1 20.0 6.1 20.0 6.1 20.0 6.1 20.0
Dimensions of Pipes and Tubes
Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Epoxy - Chemical Resistance
Chemical resistance of Epoxy to common products like Acetic acid, Alcohol, Diesel oil and more.
Fiberglass Pipes and Temperature Limits
Temperature ranges for fiberglass Epoxy, Furan, Phenolic, Polyester and Vinyl Ester pipes.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Piping Elbows - Thrust Block Forces
Thrust block forces on pipe bends anchors due to liquid velocities and internal pressures - online resulting force calculator.
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
