PP - PolyPropylene Pipes - Support Spacing
Maximum support spacing for PP - PolyPropylene - pipes depends on the operating temperature. Maximum spacing between supports at different temperatures can be found in the tables below:
PP Pipes - Schedule 40
PP - PolyPropylene Pipes Schedule 40 - Supports
NPS
(inches)
Maximum Support Spacing (feet)
Operating Temperature (oF)
60100140180
1/2 1.5 1.5 1.5 1
3/4 2 2 1.5 1.5
1 2 2 2 1.5
1 1/4 2.5 2 2 2
1 1/2 2.5 2.5 2 2
2 3 2.5 2.5 2
3 3.5 2.5 3 2.5
4 4 3 3.5 3
PP Pipes - Schedule 80
PP - PolyPropylene Pipes Schedule 80 - Supports
NPS
(inches)
60100140180
1/2 2 2 2 1.5
3/4 2.5 2.5 2 2
1 2.5 2.5 2 2
1 1/4 3 2.5 2.5 2.5
1 1/2 3 3 2.5 2.5
2 3.5 3 3 2.5
3 4 4 3.5 3.5
4 4.5 4.5 4 3.5
  • 1 ft (foot) = 0.3048 m
  • T (oC) = 5/9 (T (oF) - 32)
Polypropylene is a thermoplastic polymer used in a wide variety of applications. Polypropylene is unusually resistant to chemical solvents, bases and acids.
Dimensions of Pipes and Tubes
ABS, PE, PVC, Fiberglass and Steel Pipes - Supports
Maximum distance between supports for ABS, PE, PVC, Fiberglass and Steel Pipes.
Air - Prandtl Number
ASTM F2389 Pressure-rated Polypropylene (PP) - Dimensions
Dimensions of pressure rated PP pipes according ASTM F2389.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports.
DIN - Pipe, Tube and Fittings Standards and Specifications
Deutsches Institut für Normung - DIN - pipe, tube and fittings standards and specifications.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
Epoxy Pipes - Support Spacing
Support spacing for reinforced Epoxy fiberglass pipes.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Plastic Pipes - Friction Head Loss vs. Water Flow
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
Pressfit Pipes - Supports
Maximum distance between pressfit pipe supports.
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports.
PVDF - PolyVinylidene Fluoride Pipes - Supports
Maximum distance between PVDF pipe supports.
Recommended max. distance between steel pipe supports.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
