Plastic Pipes Operating Temperatures
Typical maximum operating temperatures for common plastic pipe materials are indicated below. Note that working pressure varies with type of material and schedule (wall thickness).
| Plastic Pipe Material | Operating Temperature | |||
| With Pressure | Without Pressure | |||
| (oF) | (oC) | (oF) | oC) | |
| ABS - Acrylonitrilebutadiene Styrene | 100 | 38 | 180 | 82 |
| PE - Polyethylene | 100 | 38 | 180 | 82 |
| PVC - Polyvinylchloride | 100 | 38 | 140 | 60 |
| CPVC - Chlorinated Polyvinyl Chloride | 180 | 82 | 180 | 82 |
| PB - Polybutylene | 180 | 82 | 200 | 93 |
| PP - Polypropylene | 100 | 38 | 180 | 82 |
| SR - Styrene Rubber Plastic | 150 | 66 | ||
Maximum Short Time Operating Temperature
- for pipes without pressure.
- PVC : 95 oC
- PP : 100 oC
- PE : 95 oC
Heat Distortion Temperature
- is the temperature where a test piece of a material placed in a heat medium with a bending load (18.6 kg/cm2) applied - reaches a specified deflection.
- ABS: 104 - 106 oC
- PVC: 54 - 80 oC
- HDPE: 43 - 49 oC
- LDPE: 32 - 41 oC
- PP: 57 - 64 oC
Vicat Softening Temperature
- is the temperature where a needle shaped penetrator sinks into a test piece a specified depth when a specified vertical load (1 kg) is applied.
- ABS: 102.3 oC
- PVC: 92 oC
- PE: 127.3 oC
- PP: 152.2 oC
Plastic Pipes Temperature Derating Diagram
• Design Strategies for Piping Systems
Piping systems design strategies - documentation, P&ID, flow diagrams - capacities and limits.
• Pressure Ratings of Pipes and Fittings
ABS Pipes - Pressure Ratings
Pressure ratings of ABS 1208, ABS 1210, ABS 1316 and ABS 2112.
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
ASTM D2661 - Acrylonitrile-Butadiene-Styrene (ABS) Schedule 40 Plastic Drain, Waste, and Vent Pipe and Fittings
Nominal pipe size, outside diameter, thickness and weight.
ASTM D2665 - Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Drain, Waste, and Vent Pipe and Fittings - Dimensions
PVC drain, waste, and vent pipe dimensions.
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
ASTM F2389 Pressure-rated Polypropylene (PP) - Dimensions
Dimensions of pressure rated PP pipes according ASTM F2389.
Bending PE Pipes
Bending PE pipe calculator.
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
CPVC Pipes - Operating and Collapsing Pressures vs. Schedule and Size
Maximum operating and bursting pressures of CPVC - Chlorinated Poly (Vinyl Chloride) - piping systems.
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
CTS (Copper Tube Sized) and CPVC Tubes - Friction Loss vs. Water Flow
Volume flow and pressure loss in CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
Dimensions of PVC pipes according EN 1401.
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
ISO 4437 - PE Pipes for Gaseous Fuels Supply - Dimensions
Plastic Pipes - Friction Head Loss vs. Water Flow
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
